Question about Ariston Technologies AWD120 13 lb. Washer / Dryer Combo
Splendide Ariston TVM63X dryer. Dryer won't start, was working fine, yesterday nothing. When you push the start button nothing happens. Circuit breaker is not tripped. What could the problem be?
Posted by Trey Rose on
5 Related Answers
Anonymous
  • 209 Answers
SOURCE: Ariston washer/dryer. Dryer not working
probably 2 separate faults no heat is possibly either open circuit on the elements which are at the top of the machine, or open circuit thermal cut outs (up to 3 of) located also at the top of the machine near to where the element is and along the flow of the hot air, you can check these with a normal electrical multi-meter, unplug machine before testing as for the vibration on spin, just look for any loose suspension legs, and or twisted drum alignment, very difficult to work on due to lack of access but sometimes just re-tightening the legs up etc, could cure the vibration hope i have helped you to start somewhere take care to note in detail any wires or parts removed or in case of accidental removal
Posted on Sep 27, 2007
Anonymous
  • 417 Answers
SOURCE: Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Posted on Feb 05, 2008
Anonymous
SOURCE: ariston margheretta washing machine/dryer
THE CYCLE WONT STOP CLICKING ROUND
Posted on Feb 16, 2009
Garry Clelland
  • 251 Answers
SOURCE: Ariston AWD 121 wont work
make sure the water supply is turned on , a small red and blue tap usually under the sink
Posted on Nov 11, 2009
Anonymous
  • 6 Answers
SOURCE: My dishwasher doesnt start
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Posted on Jan 14, 2010
New tvm63x splendide. Dryer stops and restarts during drying cycle. What could be causing this? Thanks.
Check for a lint build up in the vent hose. Too much will trigger a sensor in the dryer to shut off to prevent a fire.
Nov 19, 2014 | Splendide Washing Machines
Dryer won't start
the timer could have went out or maybe the door switch is stuck open
Jan 08, 2013 | Dryers
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
GE gas dryer won't start
you need a new motor
Apr 11, 2012 | Dryers
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Hi, i´ve been using a maytag dryer for 5 years. Yesterday when I tried to use it, the start button didn´t work... nothing happened when I push the start button. I checked electricity, but it...
heatman101
Oct 19, 2010 | Maytag Dryers
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Washing Machines Logo
393 people viewed this question
Top Ariston Technologies Washing Machines Experts
Marvin
Marvin
Eric Taylor
Harrie
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
