In settings, find INPUT or SOURCE, select CABLE and go from there. To find channels on when using the ANTENNA mode, you have to have a DIGITAL antenna hooked up to the TV. It will then search for any stronger digital signal. Most of the time if you move the antenna after the signal search, you will have to do another search to receive the signal.
SOURCE: panasonic tv channel reset
Unplug your tv for 24 hours and replug. This should set your tv back to ch 3
good luck----------------tomtaso
SOURCE: AUTO PROGRAMMING T.V.
Your TV is in Showroom Mode - to change:
Menu>Picture>Mode>Power up>Home
Then go back and autosearch channels.
SOURCE: sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
SOURCE: TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal. Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly. This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs. I have the cable input on a different "input" to make it work. Hope this helps. Call TIVO tech assistance because they are the ones who talked me through this.
