Question about Jensen Audio Players & Recorders
Can I input a Satelite radio receiver into my Jensen JSM 96; ..................If so how?
Posted by Joseph Fantasia on
Clyde Hanson
    Sergeant:
  • 221 Answers
Does your Jensen have the AUX inputs on the back or front? You would need to find a Satelite radio with the Outputs that will plug into the AUX Inputs. Some radios have a special input connections for Satelite radios, so check the Manual.
Posted on Jan 25, 2019
1 Related Answer
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
Posted on Jan 28, 2009
Color codes for my jensen eqa 111. And I'm hoping the side with the rca's is the "Out" side
Contact Jenson direct. They are a great company. There is nothing online
Jensenmobile Mobile Audio, Multimedia, Receivers, Speakers ...
jensenmobile.com
Mobile audio performance upgrades for cars and trucks. Multimedia, Receivers ... Multimedia - Jensen Electronics ... Amplifier. Speakers - Jensen Electronics ... ‎Product Categories · ‎Support · ‎Contact Us · ‎Multimedia
ASA - Jensen
www.jensen-electronics.com
JENSEN Heavy Duty develops stereos, speakers, amplifiers, and sound systems ... Component video input x 1 (YPbPr); Stereo audio input x 1; HDMI input x 2 ...
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
1helpful
Jensen Troubleshooting
be sure its in the right input/ output channel.
its always a small detail, recheck your wiring.
I try to connect a satelite to optical audio input for a digital radio signal. This doesn't work. Is it only possible to use a coax input cable for the radio signal?
The nature of whatever is on the upstream side of a digital signal is invisible to the device at the other end of the cable. Bits is bits, as we say. The undefined 'satelite to optical audio' device is probably at fault or not set right. PLUS, on theOnkyo you have to assign digital inputs. Read the manuals.
I just reactivated my satelite radio service but my Delphi is not turning on. Any advise?
Observe that the device power cable inputs are in place. For example, if device was installed into a car ascertain that that the connections are in place or battery power runs to radio system of long since has been dislodged. familirise with the radio devices power on buttons.
How do you tune in tv channels when you only have a signal input from a satelite dish and no sky decoder. TV is a sharp lc-32l400x with built in freeview. Can we plug dish straight into TV aerial port...
You require a satelite decoder/receiver for your dish and an aerial for your TV.
The choice is yours. Plug a satelite receiver, for freesat, into the A/V input on the TV or have an aerial installed for freeview.
Need remote code for programming a bell expressvu receiver
JVC DVD 0558, 0623
Regards,
VOTIT
Need to connect tv, satelite and dvd to yamaha rxv1700 receiver
hello i think the question is how to connect two equipment (dvd and directv) your tv has video 1 video2 aux, put one at any input and the sounds out from tv go to receiver inputs,this way you listen what is on tv in your amplifier....................saludos
Can i hook up to my satelite dish direct or do i have to go thru my receiver first. Thanks; Delmar [email protected]
The satelite dish will not pass-through the video/audio from your DVD player. You will need to find an open area (preferably DVD selector) on your receiver to input the DVD video/audio. Most satelite boxes are one way devices.
Satelite box --> Receiver (satelite input)--> TV
DVD Player --> Receiver (DVD Player input) --> TV
or
Satelite box --> TV
DVD Player --> TV
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
