SOURCE: Toshiba 3530c estudio waste toner error message.
Your waste toner box is located inside the front cover on the far left side of the copier. There is a plastic cover that is just clipped in (no screws) and just pops off, the waste toner box just slides out from there.
SOURCE: toshiba estudio 450 Used toner cartridge is empty
replace the ic of toner cart. problem will be solved
SOURCE: toshiba estudio 182 drivers
Go to http://copiers.toshiba.com/support/index.jsp and select your copier from the list (B/W Copier -> e-studio 182). IMPORTANT: Read carefully the "Read me before downloading driver" and download only the appropriate driver.
SOURCE: toshiba estudio 207 toner not recognized
press 0 & 8 simmuletry then press 695 and set it 0 hope problem solved
