Last week display goes on, i start running, display turns off. i get off turn on/off switch it goes back. then shuts off again, belt and speed etc seem fine but display goes blank blue screen with no display
SOURCE: Blue Tint
Most likely cause would be a loose solder connection that expands as the set warms up until it no longer makes a connection. You may get the blue to come and go by hitting the side of the cabinet after the set is warmed up awhile. (don't hurt your hand doing this, and don't keep doing it to "fix" the set. The connection will have to be located and repaired). Otherwise, there could be a component going bad, including the blue picture tube.
SOURCE: Screen displays fine for a second, then goes blank
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
SOURCE: Monitor displays breifly then goes to blank screen
The green power light indicates that the monitor is receiving from the
computer correctly. I suspect it is going into high voltage
shutdown. There is a safety circuit that monitors the high
voltage and shuts the monitor down if it sees anything amiss. So
the monitor comes on and then shuts off. High voltage problems
are generally not worth trying to repair. Another example of a
worthless safety feature. High voltage failures are not
dangerous, and adding the safety circuit just kills the unit when it
may have some life left or worse, sometimes it is the shutdown circuit
itself which fails!
Hope this helps.
SOURCE: Monitor goes blank less than a second after turning on.
the moniter may be having some technical errors maybe the IC's has got corrupt
you need to call the seller of the moniter
SOURCE: hp mini 1000 - no startup display
you got error this windows/OS system so u need to re-install the OS/Windows..good luck and have nice day
