Question about Konica Minolta Magicolor 4690MF Multifunction Laser Printer
Konica Minolta Magicolor 4690MF gives 0502 error.
Konica Minolta Magicolor 4690MF gives service call 0502 on display. This happened after I tried printing an overhear transparent.
Posted by vassil_iliev on
Anonymous
    New Friend:
Machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
Renierf
  • 97 Answers
The fuser temperature is too high. There is probably some residue from the transparency left on the thermister or the thermister went faulty that causes a wrong reading. The only solution would be to have the printer serviced.
Posted on Aug 05, 2009
Konica Minolta Magicolor 4690MF I have a caution error tray2 open close tray2 can someone help close tray2
Check the sensor for tray #2. Another remove the tray #2 check for broken acturator and or broken tabs that go into the machine to indicate the printer draw two is closed. Lift the printer off tray two use just one and bypass does that work eliminates the circuit board of the machine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 30, 2015 | Konica Minolta Magicolor 4690MF...
Sanner unit not moving how to reset error code C0620 on konica minolta
Check the scanner lock on the left side of the scanner
Apr 09, 2014 | Konica Minolta Magicolor 4690MF...
Konica Minolta Magicolor II
WOW. now that is a LEGACY Minolta Machine, Konica Minolta web site does not even list that machine try this site for a service manual
Service manuals electronic components datasheets and equipment schematics...
Feb 17, 2014 | Konica Minolta Magicolor 4690MF...
Konica minolta 4690mf doesn't recognize yellow toner cartridge
ARE YOU USING GENERIC TONERS? IF YOU ARE THAN YOUR GONNA HAVE TO USE ALL GENERIC NO MIXED TONERS.
Mar 26, 2013 | Konica Minolta Magicolor 4690MF...
How to connect the printer to the computer?
You use the USB port on the rear of the unit. Then install the printer drivers, see chapter 4 in the manual:
http://static.highspeedbackbone.net/pdf/Konica-Minolta-Magicolor-4690MF-Printer-Manual.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 15, 2010 | Konica Minolta Magicolor 4690MF...
Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
4,032 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
