Question about MAG Computers & Internet
Hi i have mag 254 but i forget Authentication login and password
Posted by Vijaya Jeyakumar on
Robert Miller II
    Habit-Forming:
  • 98 Answers
Follow the instructions at the following link to enter the BIOS and Factory Reset the box.
http://www.cs.satarabia.com/how-to-enter-the-bios-setup-mag-250-bootloader-menu/
Posted on Jan 23, 2019
3 Related Answers
zpowx2
  • 108 Answers
SOURCE: FORGET PASSWORD FOR ADMINISTRATOR LOGIN
Many people forgot their admin password. You should prepare a password reser Disk at hand. Free download windows password unlocker from http://www.passwordunlocker.com and then DIY a password reset disk. Just a few steps, you can unlock your comouter with windows password unlocker.
Posted on Jun 24, 2009
krbshg
Banjade
  • 430 Answers
SOURCE: i forget my login password for my microsoft windowsXP proffessional
If you want to reset your windows password then i'll suggest you to download Hiren's Bootable CD. It contain a freeware application which can reset or remove windows password.
Google and Download Hiren's Bootable CD
Posted on Aug 08, 2012
iampritshah9
Prit Shah
SOURCE: i forget login password of router
just hard reset your router
Posted on Dec 12, 2015
Which Default Passwords Are Used on S Series Switches?
On the S series switches of all versions:
· When you log in a switch through a console port, no default user name or password is provided. The system asks you to set the user name and password when you log in to the switch for the first time.
· Before you log in to a switch through Telnet, create a Telnet account.
· You can set the Telnet login authentication method in the VTY. If the password authentication mode is configured, set a password in the VTY. If the AAA local authentication mode is configured, set the user name and password in the AAA view. If the remote AAA authentication mode is configured, set the user name and password on the AAA server.
May 27, 2016 | Huawei Computers & Internet
Tip
How to recover sql 2000 sa password
Microsoft SQL Server 2000 is a full-featured relational database management system that offers a variety of administrative tools to ease the burdens of database development, maintenance and administration. It operates in one of two authentication modes: Windows Authentication Mode (the default) or Mixed Mode.
When you install the SQL Server 2000, you can log in the server with Windows Authentication and SQL Server Authentication if you select mixed mode authentication. If you select Windows Authentication, you cannot assign a sa password during installation. However, you should set the sa password after installation.
It is very easy for one to set sa password in SQL 2000. Just follow the below steps:
* 1. Expand a server group, and then expand a server.
* 2. Expand Security, and then click Logins.
* 3. In the details pane, right-click SA, and then click Properties.
* 4. In the Password box, type the new password.
The type of client connections determines the choice of security mode. If all of the incoming clients support trusted connections, you can use Windows Authentication Mode. If some clients do not support trusted connections, you can select Mixed Mode.
If you forget the sa password, you will need to use MS SQL Server Password Unlocker to reset sa password SQL 2000. MS SQL Server Password Unlocker is easy yet powerful SQL Server password reset software for you to reset SQL password, including reset SA password and other user passwords. It provides you an easy and safe way to reset SQL Server password for Microsoft SQL Server 2000/2005/2008 in a minute. No need for you to reinstall MS SQL Server on your PC. The file in master.mdf format is enough for you to recover sa password SQL 2000.
Steps to reset sql password 2000 for sa as follows:
* 1. Download and install MS SQL Server Password Unlocker.
* 2. Click the application icon to run it.
* 3. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
* 4. Select sa account, click Change password button to reset sa password.
* 5. Type a new password, and then click OK to finish your operation.
Note: This method to reset sa password in sql server 2000 is usually applied when you cannot login SQL Server 2000 by Windows Authentication wile you forget system administrator login password.
More information about sa password:
According to Microsoft, System administrator (sa) is a special login provided for backward compatibility. By default, it is assigned to the sysadmin fixed server role and cannot be changed. Although sa is a built-in administrator login, do not use it routinely. Instead, make system administrators members of the sysadmin fixed server role, and have them log on using their own logins. Use sa only when there is no other way to log in to an instance of Microsoft SQL Server.
on Oct 19, 2010 | Computers & Internet
Kindle say authentication problem when trying to connect to wifi
Im sure you would have typed wrong password. please make sure you have correct password typed.
-regards
Mar 01, 2014 | Amazon Kindle Fire HD
Reset my password l forgot old one verity password my laptop toshiba satellite D850 windows 8 please if know how can im reset? not worked all my keyboard?
Windows 8 when configured usually uses a microsoft account. When it asks for your password, what does it say your login name is?
If there is a login account such as [email protected] then you use a microsoft login account.
If it simply says "Robleh" then you will be using a local account. Here are some suggestions on how to reset your password in windows 8 for each situation:
http://pcsupport.about.com/od/windows-8/f/forgot-password-windows-8.htm
I hope thiis helps!
-Rogue
Jan 01, 2014 | Mag Innovision Verity 4338VLT...
How can i change the password? the problem is i forgot my old pass work.....
Hi
Which password for login password or security key. if you forget the login password then you reset your router and put the password admin, and if you forget security key then lo problem login and open the router go the wireless setting and change WAP or WPA1 what ever you select your pre shared key.
Jun 02, 2011 | D-Link DIR-615 Wireless Router
Kyocera 3035 scanning to e-mail - error code e024
Hi! EO24 will mean SMTP authentication error. Consult with your network administrator to verify that the login account name and password required for SMTP authentication are correct. Hope this helps and thank you for using FixYa!
Sep 13, 2010 | Office Equipment & Supplies
KyoceraMita KM-4050: System Board reset for authentication
Login with 5050 as the username and password via the web browser and turn off authentication.
Nov 27, 2009 | Office Equipment & Supplies
We lost the user codes for our ricoh ft4522. how
select user tools, admin , address book you should be able to see the pre programmed user codes. there also should be an option to view or print out the codes
Oct 15, 2009 | Ricoh Aficio 450 Copier
Acer 7720g f11 does not working in order repair my pc to factory image...i have the dvd recovery and i have testing a couple of times the settings of hdd ( os or fat 32 with partedit32).Also when i use the...
Hi there.
If F11 is not workings as it sometimes does, then pop the recovery DVD in the drive and try hitting F12 as the computer starts up so you can change the boot order without going into the bios.
If you do not have this option the enter the bios by hitting F2 as it starts up, once in the bios look for the boot order and change it to CD/DVD as the first boot device, hit F10 to save the changes and exit the bios, the computer will restart and you should be able to boot from the recovery disk and restore the PC to factory condition.
Please post back if you need anymore assistance.
Good luck and thanks for using FixYa!!
May 25, 2009 | Acer Aspire 7720 Notebook
How to enter authentication details for the Document Server ?
Hi there if you type in the internet explorer the ip address there you will have the machine information. Then login usually the login is
User name = Admin
Password = password or just enter leave blank
Once you are in there you will be able to change the details you need.
Cheers J
Dec 26, 2007 | Ricoh Aficio 3025 All-In-One Laser Printer
Computers & Internet Logo
137 people viewed this question
Top MAG Computers & Internet Experts
Andrew Taylor
Andrew Taylor
STEVE SPAM REMOVER
Terry
Terry
Are you a MAG Computer and Internet Expert? Answer questions, earn points and help others
