Question about Ricoh Office Equipment & Supplies
I have Ricoh MP C3003 Jpn
Wanted to print landscape but comes out to be portrait
Posted by Bob Choi on
5 Related Answers
Marty marty
  • 883 Answers
SOURCE: Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
Posted on May 31, 2007
Anonymous
SOURCE: Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Posted on Nov 29, 2007
Anonymous
  • 7 Answers
SOURCE: print orientation
If you are printing from the included software, it has options for labels with vertical printing. If printing from a third party program, you can go to the dirver settings and change the printing orientation.
Posted on Dec 31, 2008
Anonymous
SOURCE: HP Color laserjet 4700 is printing in landscape
check paper settings in paper handling to set
at plain paper/ letter. or reset factory defaults.
check paper size on tray if app, set to standard or
letter ,not custom
do cold reset . must reinstall network info afterwards.
Posted on Jan 20, 2009
Anonymous
SOURCE: Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
Posted on Dec 30, 2009
Printer prints portrait landscape setting
Are you confirming the settings in both the PC/User settings and the defaults on the Ricoh device? The printer will normally only follow the commands given by the user/PC. If somehow the properties or page settings are set for 2 images to a page, it will produce such results.
Apr 17, 2014 | Ricoh Office Equipment & Supplies
Ricoh Aficio MP C3300
Go into the print driver and the machine settings and make sure the paper size and direction are all in agreement with each out and the paper in the tray itself. If screen icons do not agree with the size and direction of the paper in the tray you will have a lot of weird problems.
Jul 22, 2017 | Ricoh Office Equipment & Supplies
At college we have a w7200, how can we print across the paper rather than down it, for example a panoramic image across the width of the paper and say 20cm high
Try selecting LANDSCAPE as opposed to PORTRAIT by using the proper print menu in your application rather than the simple print icon from most tool-bars.
You can usually find it in the FILE menus
Apr 20, 2010 | Canon imagePROGRAF W7200 InkJet Printer
I have an hpdeskjet 960c. Will not print
follow the steps provided below..
  1. Open Ms word
  2. click on file
  3. click on page setup
  4. click on land scape and close the window..
Aug 22, 2009 | Office Equipment & Supplies
Portrait v. landscape
Check the paper size dial on the paper drawer. Most likely it is incorrectly set - either size, and/or orientation.
Jul 06, 2009 | Ricoh Aficio 2015 Copier
I am using a Ricoh Aficio MP C5000 multifunction device. The device doesn't allow me to print in landscape from any application. In word if i change the orientation to lanscape it tells me that the margins...
My name is Michael Harris and I am a representative for Ricoh. Your printing issues are unusual, however I am sure I can help you resolve them. 818-620-4659
Mar 18, 2009 | Office Equipment & Supplies
Printing Problem
Try changing the paper setup of the printer driver, from the Start menu - Printer and Faxes.
Select portrait and click apply.
Joseph
Jul 07, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Fonts do not print as large as needed is printing in landscape even when if portrait is wanted
Go to printer properties and in bottom right selct Portrait as opposed to Landscape.
What printer is it? New/~Old?
Feb 13, 2008 | Computers & Internet
Copier Orientation
clean the three paper selection sensors on the feeder.better you select the paper tray according to the paper orientation instead of using auto paper slect function
Nov 21, 2006 | Ricoh Aficio 2027 All-In-One Laser Printer
26 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
