Question about GE Washing Machines
I have A GE model 1950 washer Not Spin cycle in it will not drain Can you help
The washer is approximately less than a year old it has just started doing this And it is a top load washer
Posted by jason tolbert on
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
GE top load washer will fill, but won't drain, spin, or agitate
Sounds to me like its just a lid switch issue. The washer needs to know that the lid is shut beforeit will advance. A model # would help. Its a basic fix and shouldnt be too expensive. Certinly chepaer than a new one. Hope that helps. Dave www.washermd.com
Dec 14, 2008 | Washing Machines
GE washer will not go to spin cycle or drain.
Possible lid switch not fully engaged. It will no drain or spin if lid switch is not fully engaged. I would also check the drain line for pluggage.
Oct 22, 2008 | Washing Machines
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
