Question about AT&T Motorola RAZR V3 Cell Phone - Black
SIM unavailable on screen and phone cannot connect to network so no calls can be received or placed.
Posted by wjmaurer on
CaptDP
  • 133 Answers
Try cleaning your sim card contacts and if that doesn't do it you need to go to a at&t store and get a new sim card.
Posted on Aug 06, 2009
Network error samsung galaxy ace please help
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Nov 04, 2012 | Cell Phones
Samsung galaxy gt-s5360 network unavailable
First Option:
Secend Option:
Sep 20, 2012 | Samsung Galaxy Y Gt-s5360 - Black unlocked...
My phone says limited service and i can't send text or calls.every time i send message it says unavailable service. When i try to call it says emergency call only... What should i do.. any suggestion...
THAT MAYBE BECAUSE 1. EITHER NETWORK IS UNAVAILABLE 2.MOISTURE IN SIM-SO TRY REMOVING AND REINSERTING THE SIM 3.UR SIM IS LOCKED DO VOTE FOR ME IF IT WORKS.BEST OF LUCK.
Sep 03, 2011 | Samsung Star GT-S5233 Cell Phone
Whenever i try to send a text message, a box pops up saying " Network Service Unavailable" but i can still call people with no problem ??
Hi,the message that pops up saying "Network Service Unavailable" might be from the message settings not correctly set and it is unable to send messages.
You can go to the message setting options on the cell phone to confirm if it is rightly set.
To be sure, you can also use the sim card on another phone to confirm, by using the a friends phone to send a message.
If the message settings are correctly placed, the problem might be from the sim card. You willneed to contact Sim service center for help to rectify the problem for the Sim card..
Take care...
Feb 14, 2011 | Cell Phones
Pls help me,,before,when am calling or receiving,the network will disappear,later it will come back....i now angrily smash it on the floor,since then it has been writing sim card rejected......
If the network was unavailable it may have been a problem with your network provider you may have been in an area with low connectivity and as for the "Sim card rejected" when you smashed bits and pieces may have came loose in your phone you might need to change your service provider and get a new phone.
Jan 09, 2011 | Cell Phones
Cannot make or receive calls from tracfone;the only thing that shows on mainscreen when trying to make calls network is unavailable or emergency only.
remove your sim card clean the pcb or circuit in it once then insert again and try if problem continues contact your operator
Mar 14, 2010 | Cell Phones
Dropped calls No Network service Network unavailable SIM card failed to register
I had that happen with my phone before. i called them and they told me i needed a new sim card. i bought a cheap one on eBay, popped it in my phone and never had a problem since. sounds to me like you need a new sim card. good luck :)
Feb 04, 2010 | Nokia 6300 Cellular Phone
T-mobile blackberry "radio path unavailable" ??
Perform the following steps to try and resolve the issue:
  1. Remove the battery cover.
  2. Remove the battery (while the device is still powered on).
  3. Remove the Subscriber Identity Module (SIM) card.
  4. Reinsert the SIM card and the battery to reset the BlackBerry smartphone.
Sep 21, 2008 | RIM BlackBerry Pearl 8100
It says "network is unavailable"
Please check whether you have enabled "automatic " settings or "manual settings" in the settings menu or your phone. Change vice a versa .Restart your phone. I hope this will solve your problem. Also try to remove and reinsert sim.
Mar 09, 2008 | LG KE820 Cellular Phone
AT&T Motorola RAZR V3 Cell Phone - Black Logo
Top AT&T Cell Phones Experts
Ekse
William Alequin
Muntejaya Ginting
Muntejaya Ginting
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
