Question about Luggage & Travel
Just bought an Apex luggage and it was locked. How do I get it open , not knowing the lock
Posted by Denise Fife on
5 Related Answers
Richie_asg1
Richard Perkins
  • 1036 Answers
SOURCE: Master Lock luggage lock
This PDF document explains it carefully -
http://www.masterlock.com/faq/pdf/620_630_646_647_Instruction_Sheet.pdf
Hope this helps.
Posted on Jun 12, 2008
Anonymous
SOURCE: FORGOT THE CODE
Try from 000 to 999
Posted on Aug 22, 2008
Anonymous
SOURCE: Set luggage lock
the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
Posted on Jan 03, 2009
Anonymous
SOURCE: my samsonite hardcase luggage's centre no.lock not able to close
problem sloved
Posted on Oct 21, 2009
Anonymous
SOURCE: i found my lock broken for my american tourister
tnx i got a lock from an old luggage
Posted on Feb 15, 2010
Tsa002 change combination
Most combination luggage locks can be reset when they are open. The combination wheels can't be turned unless the lock is being reset. So either the wheels show the correct combination, or you will be able to turn them to a new combination. The lock that is "locked outside the hole" was either not relocked after inspection or it's in reset mode.
Jul 04, 2014 | Locks & Locksmithing
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
Luggage lock open
I try to reset the lock on my luggage and I block it is only one pin locks and the other one is stuck inside
Aug 09, 2013 | Luggage & Travel
Presto combination lock
By frequently resetting your lock combination, you decrease the chance that someone will break into your luggage.
If someone watches you open your luggage at baggage claim while going through security or at a hotel, they may break into your luggage when they encounter you on another leg of your journey.
Change your lock after every major flight or trip to help keep your items safe.
Avoid easy to guess passwords, as well, such as sequential numbers, all the same number or birthdays.
Open your lock by inputting the current combination.
New Prestolocks have a factory set combination of "0-0-0."
Turn the shackle 180 degrees.
Press the shackle down and turn it 90 degrees to the left or right.
Input the new combination.
Move the shackle 90 degrees so that it is 180 degrees from its locked position.
Take your hand off the shackle and pull it out.
Turn it back to the locked position.
Push the shackle into the lock and turn at least one of the lock's dials.
Write down your new combination.
Keep this paper in a safe place for future reference.
Jun 20, 2013 | Extensis Suitcase X1
Drilling out lock on scooter luggage box
if you have a new lock & key assembly,you can drive a small chisel or stout flat blade screwdriver into the old key hole about as far as a key would go. with a wrench on the chosel,turn it like you would the key to open it.now look inside,there is a clip or a nut holding the cylinder in place.R&R.
Sep 22, 2009 | 1991 Honda CRX
Set luggage lock
Dec 24, 2008 | Locks & Locksmithing
Luggage & Travel Logo
214 people viewed this question
Top Luggage & Travel Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Luggage and Travel Expert? Answer questions, earn points and help others
