Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red
View products that this article applies to.
if (!loadTOCNode) {var loadTOCNode = function(){}}
Expand all |
Collapse all
if (kb_page_object)
kb_page_object.kb_imageExpandHoverText = 'Click to expand this image';
SYMPTOMS
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360...
loadTOCNode(1, 'symptoms');
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red.
Back to the top
CAUSE
The three flashing red lights may indicate that there is a hardware problem with...
loadTOCNode(1, 'cause');
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console.
Back to the top
MORE INFORMATION
If you are experiencing this problem, you can submit a console-repair request on...
loadTOCNode(1, 'moreinformation');
If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
- When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles:
906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red
906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange
906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
- Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit
http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page.
Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit
http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
red lights
the light is green
