Question about Photography
What to do if the film cover wont eject on my instax mini 8 and if the red light suppose to flash or stay on continuously
5 Suggested Answers
Turnip95
William
  • 72 Answers
SOURCE: flashing red light and disk wont eject
Im afriad your going to have to buy a new playstation3 console. Sony no longer produce 60Gb consoles and they will not replace or repair your console. Im guessing youve had your 60Gb for over one year so theres no warranty.
Sad to say but you have to buy a new one. eBay have some good offers. ;)
Posted on Jul 28, 2009
Anonymous
SOURCE: PS3 power wont stay on goes from green to flashing
i had that problem and it was the fan had come loose and wouldnt cut on
Posted on Jan 05, 2010
paul proctor
  • 4102 Answers
SOURCE: flashing red light, turns on
hi, the problem you are having is due to the ps3 over heating, if you have any warranty on it then take it back and get it exchanged, you wont be able to get the game out without it working or without taking the dvd drive apart.
to fix the ps3 your going to need to have the gpu and cpu chips heated up using a reflow station as the problem your having is with the solder on these chips what happens is when it over heats the solder cracks and you lose the connection with the circuit board so you need to get the solder reflowed to create a circuit again, its not something you can do yourself as you need special equipment to have it reflowed,
i do these repairs myself so now how difficult it is to get it right, shop around and see what price you can get, the actual problem you have got is called yellow light of death its called this as the red light flashes yellow just before it flashed red, it is worth getting fixed so shop around and see what price you can get.
if you have any warranty left then this is covered im sure sony cover this fault under warranty for 3 years but you will need to check this either by calling them or checking on their site.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts,
im sorry i couldnt give you an easy fix but without taking it apart and reflowing the gpu and cpu chip their is just no way of getting it working again
Posted on Nov 15, 2010
ashtonkemerl
  • 269 Answers
SOURCE: fuji instax mini 25 film
X-rays can fog many types of film. If you are flying you can declare that you have film, and have them manually inspect it rather than sending it through the x-ray machine.
Posted on Mar 03, 2011
flyvog03
SOURCE: My Fuji Instax mini 7s
welcome to our websit:... ╭══════════════╮ ..... http://www.voguecatch.us ... ╰══════════════╯ Wow! This site: Both cheaper and fashion, and good products. Purchase will have small gift to send. http://www.voguecatch.us was a good site. Like this discovery. ... http://www.voguecatch.us ...... ***★Nike☆jordan s-h-o-e-s $30--35★*** ****☆ Best online store ☆**** ******(U-G-G)******* ... http://www.voguecatch.us ..... ....Welcome you to visit thanks..
Posted on May 14, 2011
Is the flash off by default on start up? My light is not working.
Lomo'Instant Camera - Lomography
microsites.lomography.com/lomo-instant-camera/about/
LomographyThe Lomo'Instant has an auto flash shooting mode so you can easily shoot fantastic ...The default aperture value is f/16 and the exposure compensation dial can be ... Theflash is switched off and you can switch between N for normal daytime ... Close-UpLens Attachment (Included in the Camera plus Lens Packages): With ...
Fuji Instax 210 Instant Film Camera Review - Dan Finnen
danfinnen.com/review/fuji-instax-210-instant-film-camera-review/
Oct 2, 2013 - Here is a line of instant cameras that are still manufactured new and use film ... using the camera, mostly because your hand is already covering it up. ... Other controls include a lighten/normal/darken switch and a flash on/off button. ... Heck, if the camera didn't default into macro mode that would make the ...
Fujifilm Instax Mini 90 - Instant 'Polaroid' camera - PhotoMadd
photomadd.com/fujifilm-instax-mini-90-instant-polaroid-camera/
Jan 11, 2016 | Photography
How to fix three red flashing on instax mini 7s? I had change the battery and it work but only for a short time
  1. Amazon.com: Questions and Answers: Fujifilm Instax MINI 7s White ...
    www.amazon.com/Fujifilm-MINI-7s.../-/-/1?_... Amazon.com, Inc.Questions and Answers on Fujifilm Instax MINI 7s White Instant Film Camera. ... Sort: Most Helpful first ' Newest first. Showing 1-10 of 31 questions. 3. votes ... Now when i take photos the photo turn out black What can i do to fix Jun 1, 2015.
Jul 21, 2015 | FUJIFILM instax mini 7 Digital Camera
I have a Fujifilm instax mini 8. All setting lights are flashing. I have tried changing batteries but this has not solved the problem
You must use a better quality battery. E.g. Energizer or Panasonic. There is many fake batteries in the market. I suggest you purchase from Camera specialist at PassionGadgets.com
Mar 11, 2015 | FUJIFILM instax mini 8 Instant Film Camera
What do I do if my instamax mini 8 has all the setting lights flashing and the red light on the viewfinder on?
Had the same problem and discovered the motor driving the mechanism was not properly aligned. Remove the film. Take the back off the camera by removing all the screws you can see plus one under the cover where the film exits and 2 in the battery compartment. Loosen or remove the 2 screws holding the motor. The motor is located just down from the viewfinder, on top of the push button to take a picture. Turn the camera on and take a picture. The motor and gears should work, Let it run through its cycle and tighten the screws when the motor is in the proper position for smooth operation. I had to use 2 screws from the camera body to get the motor to stay in the proper position. ( i used the ones from the battery compartment)
camera now works as it should.
Jul 12, 2014 | FUJIFILM instax mini 7 Digital Camera
The flash sometimes doesn't work and prints out white film
Hi, once you insert the new pack of film, first shot is without flash as it's eject the film cover which is a useless film cover that cover the film protect the film being exposed. after first shot, camera will have flash. but do not open the film cover again. if you open and take out the film it will expose to light and film turn out to be white.
http://www.passiongadgets.com/
Apr 13, 2014 | FUJIFILM Instax 210 Film Camera
My instax mini 8 won't turn on.
hi there.
not sure if this link will help you out but have a look.
My instax mini 8 won turn on Google Search
Nov 17, 2017 | Cameras
Instax 8 picture
White stand for film expose to light. someone might open your film cover and pull out the film box inside contain films. once expose to light, it will appear white.
Dec 25, 2013 | FUJIFILM Instax 210 Film Camera
The film comes out all blank when I take a picture on my Fujifilm instax 210. What do I do?
try take 10 shot without any films insert to the camera.
If there is flash mean camera is working in goods condition.
It will appear black because someone had open the film cover before, therefore , it detect it's a new film box, and eject the first film cover.
film will appear black.
Sep 23, 2013 | FUJIFILM Instax 210 Film Camera
Photography Logo
176 people viewed this question
Top Photography Experts
Ekse
Marvin
Marvin
Are you a Photography Expert? Answer questions, earn points and help others
