Question about Audio Technica Audio Players & Recorders
Audio technica ear pad replacement
Audio technica quietpoint ath anc 7B please provide step by step instructions on how to replace the ear pads thank you
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 14 Answers
SOURCE: How do you replace the batteries in the Audio
Read The Manual :)
Or Try To See On The Sides Of The Headset
U Can Take It Out And Put The Batteris
-Jon Aka Mayorofsword/Sprayerz
Posted on Aug 11, 2009
I have an audio technica ath-anc7b noise canceling headphone. There is a crackling sound when I tap lightly on the left hand side of the earphone. There may be something loose. How can I open the cas
I was researching a similar answer and discovered that the left side ear piece actually is actually held together with 3 torx screws that are visible upon removing the ear pad and the padding surrounding the driver. I haven't had a chance to attempt a fix yet but remove those screws and see if you can open the ear piece.
Oct 06, 2012 | Audio Technica ATH-ANC7B Headphones
I just recently got a pair of Audio-Technica ATH-ANC27 headphones and I've noticed that when I touch the detachable cable the sound shorts out and plays through one side of the headphones.
There is a wire in the detachable cable that is broken inside so might have to cut and rejoin the broken part.Thats why when you touch the detachable cable you happen to move the wire so sound is only transmitted to one ear phone only.
Thanks and good luck
G.
Aug 04, 2011 | Audio Technica Audio-Technica ATH-ANC27...
All of a sudden sound is not coming in one of the channels (right). On pressing the headphone's band a bit sound comes on and goes off.
The cable connects to one headphone and then through the headband to the other side.
I sounds like the cable connecting them that runs through the headband has been damaged.
The only solution is the try and remove the cover from the headband and repair the cable.
Please leave feedback
Cheers
Andy
May 03, 2011 | Audio Technica Audio-Technica QuietPoint...
Tell me how to replace the cord myself, how do i get them apart? ath ad500
Most headphones have screws that hold the earpiece shells together, look under the earpads for them.
Jan 27, 2011 | Audio Technica Audio-Technica ATH-AD500...
Broken ear pad holder,need a replacement
i have this same problem. I sent them to someone on ebay to get fixed and the earpad holder broke again. I don't know why audio technica doesn't just sell the part.
Jan 21, 2011 | Audio Technica Audio-Technica QuietPoint...
How do I open Audio-technica ATH-911's? One of th...
hi.
First of all: This headphones don't have a single srew. So be extremely
carefull as everything is glued !
#1 - Removing the logo plate
This isn't need to reach the wires. Just for cleaning purposes.
Remove de soft ring-pillow from the earing.
Remove the textil thick black ring that is glued by the internal outside gently.
Look for the three black metal small wings that belong to the logo plate and
are inserted to the internal side and are glued and/or bended. Unbend them.
Then pull this wings in order to extract the plate by the outside side the logo plate.
#2: Accessing the speaker and it's wires.
This is a very carefull procedure. A mistake and you'll have scrap instead!
Remove the soft ringed pillow from the earing. In the border that the black
sinthetic leader was inserted, insert a medium screwdriver. Gently swing
the driver up and down in order to separate the plastic disc that supports
the ringed pillow from the outside hat of the earing. Do this in circles for
a couple of times or until you begin to ear the glue lightly cracking. After
this the plstic disk separates from the outside hat and all the electric
wiring and speaker are free to repair.
NOTE: A piece of advice: do NOT use instant glue or cyanide glue to
re-assemble. It would be the last repair!
Pedro Regueiras
May 20, 2010 | Audio Technica ATH-A900 Professional...
Sound is only playing in one ear.
See if my tip on headphones will help you with this problem.
Mar 30, 2010 | Audio Technica ATH-M30 Professional...
Lost sound in the right ear of my audio technica ath-d40fs
The most common problem with earphones are the wires. Usually near the end. You can carefully open the headset to expose the wire connection, and check for continuity.
Nov 28, 2009 | Audio Technica Audio-Technica ATH-D40fs...
How do you replace the batteries in the Audio Technica QuietPoint ATH-ANC7 headphones
Read The Manual :)
Aug 09, 2009 | Audio Technica Audio-Technica QuietPoint...
43 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
