Krups EA8250 Fully Automatic Espresso - Black Logo
Posted on Jan 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Krups coffee maker model EA 8250 stop making coffee and the machine point mechanical problem 08. What code number 08 stands for?
timoboon2
Level 2:
Sergeant:
  • Expert 360 Answers
  • Posted on Jan 22, 2019
timoboon2
Expert
Level 2:
Sergeant:
Answers
360
Questions
0
Helped
154717
Points
959
5 Related Answers
A
Anonymous
  • Posted on Apr 04, 2008
SOURCE: krups aroma
The basket for the coffee is located about the carafe (the round part on the front of the unit). It swings open from the right side. You should see a small ridged tab to pull toward you to open it up. Once open it will swing to the left. Put in a cone type #4 filter and your coffee, add water and you are ready to go!
Tom Torre
  • 279 Answers
  • Posted on Sep 18, 2009
SOURCE: We have a krups combo expresso and coffee maker. I
When is the last time you cleaned it out w/ vinigar?
Anonymous
  • Posted on Jan 08, 2010
SOURCE: we have a krups coffee machine ea 808 but we have
You may want to try to locate an owners manual on the internet. Try the Krups website via Google.
Anonymous
  • Posted on Jun 23, 2010
SOURCE: I have a Krups type 964 espresso maker - I can't get a good seal
the seal on the filter is broken? its a replacement part
Anonymous
  • Posted on Oct 24, 2010
SOURCE: Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Krups Ea8250 not heating. Getting automatic maintenance then pull plug and put back in.
open the machine, look at the wiring to the water heater. 1 cable is loose in the rubber/PVC cap. you have to solder it again.
How do i make my krups 8250 grind less coffee per cup
Your machine makes 4 levels of coffee. Espresso, strong espresso, coffee and long coffee. The strength is controlled by the knob on the front of the machine. Page 7 in the user manual.
Krups EA 8080 Coffee machine keep asking to clean the drawer a number of times even thought it is empty. Lastly but the machine indicate code 12. What does this code 12 meaning ?
Error 12 There was no pulse from the ejection switch so possibly a switch problem or worse still some grief on the control PCB. This will also be associated with the cleaning the drawer problem. From memory the switch/es are located above the used grounds bin.
Krups coffee maker constantly beeping, even when no water or not turned on, when making coffee it beeps turns off then beeps and turns on - getting to the point of just unplugging to stop beeping.
Hello Linda Foster,
If there is NOT an OWNERS MANUAL immediately
available.. there are a huge selection of KRUPPS
machines...
Chose from the attached list...
Find the trouble section... Read & heed
Results for krupps coffee maker var myCallback function document ready...
Hope this helps...
(or REPOST with model number for BETTER QUALITY answers).
Carnac the Magnificent
Krups Orchestro FNF243 - there are plenty of coffee beans in the machine but it started to produce very weak coffee more dirty water than coffee. How can I fix it?
I had the same problem with a 8250. I had to throw it out as the grinder stopped accepting oily beans. I suggest that you take all the beans out and take a "keyboard cleaner air can" and spray the heck out of the area where the beans get ground up. It'll spray grounds all over so do it outside!
1helpful
Filling machine necessary press ok'. HOW KAN I FIX THIS PROBLEM
The magnetic float in the water tank is probably not floating, jam something plastic between the float and tank bottom or buy a new tank.
Krups ea 8250 error code 05
I have ea8250 krups machine . It gives me error code 05
Krups ea 8250
If it doesn't grind , than there is no coffe , it will surely come as water .
Grind it first , and than brew the coffe .
1helpful
Krups ea 8260 espresso maker error code 07
Error code 05 on my krups ea 8260. How to fix it?
We have a krups coffee machine ea 808 but we have
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
