Question about Dacor Ovens
SOURCE: dacor oven ECPS127S will not heat after self clean
the problem was fixed by opening the panel between the oven cavity and the touch panel just behinf the door. you can look through the grill but to trip the reset you must unscrew the panel. you will find the reset back behind the wires Looks a red button nestled on top not very open but it should be there> i do have to say i found a step by step description on this site. but right now i can't tell you who exactly he was.
Posted on Feb 24, 2008
SOURCE: Oven won't heat.
Thanks for the tip. Had the same problem, everything seemed to work except for the heating elements. Removed the vent cover inside the door just below the control panel. Found the reset button and also found one of the large black power wiires had come loose from its connector. Turned off the power at the breaker box, checked for voltage with a meter and re-attached wire connector with insulated pliers. Oven works now. Lets call this failure "poor workmanship at Dacor".
Posted on Feb 03, 2009
SOURCE: oven won't heat after self cleaning
There is a overload thermostat located on the rear of your oven that needs to be replaced.
Self cleaning operations are not recommended by this technician.
Posted on Mar 02, 2009
SOURCE: Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Posted on Apr 09, 2009
SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Posted on Jun 28, 2009
