Question about Binatone Lands Phones
Plug in a known good handset and line cord. The simpler the better. Disconnect all other devices and make a call. If it works, disconnect line cord at the good handset and plug line cord directly into binatone and place call.
Posted on Jan 21, 2019
SOURCE: Dialling out!
Hi make sure that you don't need a prefix number i.e. a 9 to dial a outside line. The best test is to plug a normal phone into the socket and call someone from that line. If the same problem is still there then it is a line problem if not check within the machine menu that under TTI or call settings that there is no prefix number installed. If there is set the machine so it doesn't need a prefix.
I hope this helps you
Thanks J
Posted on Jan 08, 2008
SOURCE: Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Posted on Jan 26, 2009
SOURCE: No dialling tone - just a beeping sound
It sounds like the handset is not 'registered' to the base station/cradle. Solution may be in the user handbook, which you should be able to download at :
www.cordless-phones.uk.com
Posted on Mar 01, 2009
SOURCE: Nokia N72 mobile phone, am unable to hear dial
increase the volumes of ring tones ,unscrew the phone to check if the ringer is not faulty or damaged,repair or replace it ok
Posted on Jul 11, 2009
SOURCE: unable to work phone no loop current what does this mean
Your fax machine cannot find a dial tone. make sure the ANALOG phone cord is plugged into the LINE port.
Posted on Aug 01, 2009
Jun 28, 2015 | Binatone Lifestyle 1910 Twin Cordless...
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Oct 05, 2010 | Lands Phones
Aug 18, 2010 | Office Equipment & Supplies
Aug 01, 2009 | Philips FaxJet 375 Plain Paper Inkjet
Jul 11, 2009 | Nokia Cell Phones
Aug 15, 2008 | Uniden Cordless Phone
63 people viewed this question
