Cell Phones Logo
Question about Cell Phones
My sim card block PUK
How can i open it with pun no.. My no phone (REMOVED BY MODERATOR)
Posted by Ramliey Muhamad on
My ufone was block i need open my sim[03343020195]
PUK Code
PUK stands for Personal Unblocking Key. This is a unique eight-digit code specific to your SIM card. This is required when the PIN number to unlock your mobile phone is entered incorrectly 3 times. You are then given 10 attempts to enter your PUK code. If an incorrect PUK code is entered after the 10th attempt, you will block your SIM card permanently and will require a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack. If you do not have this then - Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give them your account details and they have confirmed your identity. For details to obtain the PUK code for the SIM card, please click on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
Dec 26, 2012 • Cell Phones
My Phone Sim card has been blocked,,so pls tell me steps to open it.
The step to take is for you to enter the PUK number of the simcard so it will enable you to get ***** to your sim card,Firstly PUK means, personal unblocking key. It is simple to get it off the phone. The PUK can be found mostly in the pack where you took out the sim card of the phone from. You will see some codes on the pack of the sim, there you will also see the PUK code, enter it and it will ask you to enter a new security code. Then you enter it and the sim will be unlocked.
PUK mainly blocks the sim card from working on the phone. you can use a new sim card on the phone and it will work perfectly fine.
If you do not have the sim pack, you can contact the customer care or help center of the sim card and they will give you the PUK code. try that with another phone.
Thank you for using fixya.
caseytech
2answers
Pin code bloced enter puk codw
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At the link below you will be directed to a tip i wrote on how to recover your PUK code.
Click HERE to navigate.
Kind regards
Lock123
My sim card is blocked. i need puk code to open it
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Jul 19, 2011 • Cell Phones
I cant open my cell phone its block pls tell me my puk code
1helpful
My phone will only allow me to use the emergency call number, It say PUK blocked? Please assist.
A PUK blocked message pops up after one enters the wrong PUK code 7 or 10 times in a row, depending on the service provider. A PUK code is required only after one blocks the SIM PIN code.
Many times, it may so happen that you block your PIN code. You will need to call the customer care of the service provider of your cell phone for the PUK code or refer the SIM certificates for the PUK code. If you enter the wrong PUK code 7 to 10 times in succession, it will lead to PUK blocked. After entering the wrong PUK code 10 times in a row, the SIM card becomes permanently invalid or locked. The only solution is to purchase a new SIM card.
PUK blocked requires you to get a new SIM card. It does not matter whether you use a Nokia Cell Phone, LG Cellphone, Motorola Cell Phone, Samsung or Sony Ericsson handset. The handset is not the one that's deactivated, but its the SIM card that gets blocked. So, contact your network store for further help and getting yourself a new SIM card (new phone number). I hope this article on PUK blocked on cell phone has helped you find the solution to your phone problems.
18helpful
8answers
Unlock the puk code for aircel perpaid
PUK or pin unblocking key, usually comes up together with your sim card, be it on a paper, receipt or at the back of your sim card card. it is usually the unblocking key for your pin. normally, puk is for your sim card not to your phone, but, if the phone depends more on the sim, either if you remove the sim and open your phone, it will not open. usually, this is possible for phone who don't have an offline mode. if you lost your PUK, then, the possible way to acquire this, is to contact your network provider and ask for your puk code. if your phone has an offline mode, try inserting a sim that the pin is not activated and check.
16helpful
11answers
Need a puk number to my viva sim
my number is 33734927<br />i need puk number.<br />
2answers
Puk blocked
Hi and welcome to FixYa,
A PUK (Personal Unblocking Key) is the code required for enabling/unlocking a sim card. This disabling/lock is a result of erroneously entering the PIN (Personal Identification Number) multiple times. Depending on the SIM card issuer, erroneously entering the PUK code multiple times would result to a permanently blocked/disabled SIM card. The PUK code is an OTW (one time write) only and therefore the only way to open the card is with the PUK code.
In all instances, it has nothing to do with the phone itself but with the SIM card, hence, the LG Vu CU920 would still work with another SIM card.
Hope that this be of initial help/idea. Good luck and thank you for using FixYa.
Top Cell Phones Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Cell Phone Expert? Answer questions, earn points and help others
