Question about Cambridge Audio Audio Players & Recorders
The first thing I would try is swapping the speaker wires on the back of the amp and see if the problem moves as well. Then you know what your speakers or speaker wire. If that's not the case, then try switching the left and right
from your sources and see if the problem follows. This should get you a pretty good idea of what's wrong
Posted on Jan 20, 2019
SOURCE: The left channel in my cambridge azur 640
have the volume control cleaned by a spray of electronic contact cleaner. If the carbon coating material is already wiped-out due to use, have the part replaced
Posted on Aug 03, 2009
SOURCE: I have a Cambridge Azur
Yes, you are right. That's a protection feature to prevent burnouts. Typically it appears when your speakers are sucking up a lot of load from the amp. Please check your speaker impedance and the amps' output impedance and ensure the wiring are properly done. Some amps are soo sensitive that they may cut-off after certain level due to overload.
Posted on Mar 06, 2011
SOURCE: cambridge azur amp 640a working
Looks like the fuse blown.. or the classic symptom of electrical fault inside the amp. 640A uses a sensitive protection circuit often ends up in this irritating situation. Normally, there is nothing much you can do, but just check your wall plug connection for Open Ground or Left & Neutral reversed issues. If the wall plug is free of error, then you should better contact CA technical support.
SOURCE: I have a Cambridge Audio azur 640A amp. When
Switch the channel on the phono to isolate the problem within or outside of the amp.
Posted on Aug 12, 2011
