Question about Russell Hobbs Blenders
I need replacement parts : plastic base, blade and bearing assembly plus seals for model RHB314
Posted by Barry Lockwood on
5 Related Answers
Anonymous
SOURCE: Kenmore KMB048 Blender
1800KENMORE
Posted on Aug 22, 2008
Anonymous
SOURCE: replacement parts
My blade assembly leaks just as you are describing. I found a website that offers replacement parts for Black and Decker appliances:
[Note: I have not ordered from this site yet so I can't say how reputable they are.]
They offer the glass jar, blade assembly, and other parts for the BL1900R. Judging from reviews, it may not be long until something else goes wrong.. I am gong to order the replacement part this one time. If anything else goes wrong though, forget it. Too bad. Black and Decker usually makes good stuff.
Posted on Mar 24, 2009
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: CA 4203 model #, Smoothie 700 Pro
Here's the parts order form:
http://www.focuselectrics.com/finditem.cfm?itemid=4287
-Tha Mp3 Doctor
Posted on Mar 27, 2009
lynnjeff_199
SOURCE: I need to replace the
abtec has Back to Basics appliance parts including parts for Back to Basics coffee ... PARTS AND ACCESSORIES FOR BACK TO BASICS BLENDERS AND SMOOTHIE MAKERS ...
www.abtecparts.com/
Has blade assembly
Posted on Jun 06, 2011
jsnweed
SOURCE: Hello, I ordered a replacement coupling
Hope you have solved your problem by now, but put a flathead screw driver in the bottom of the blender to hold the blender shaft in place then turn the gear by hand or with a plyers and it should just screw off, it is reverse threaded...
Posted on Aug 14, 2011
In the base, when I put the food in the cup, and the blade cup in doesn't fit the base. it appears the the blade doesn't go down in the base. I need help, I don't know if the base
Lots of questions, not a lot of information. Is the rubber sealing washer in the wrong place. I have no idea what model/brand you have but on most blenders the rubber seal will go between the beaker and blade assembly, not the blade assembly and the collar.
Jun 18, 2015 | Blenders
Replace ball bearing
Part of the blade assembly or drive socket assembly?...
check here:
Amazon com vitamix wrench assembly Home Kitchen
Jan 30, 2014 | Vitamix Blenders
Can you repack the blade bearing on Vitamix Blenders?
On the Vitamix blender models we have here in NZ it is not possible to repack the bearings, you just purchase a new blade assembly complete with bearings and the driving clutch.
Nov 11, 2013 | Vitamix Super 5000 Work Top Blender
Vitamix TNC 60 oz container leaks when in use. how to replace seal and or bearings?
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Oct 21, 2013 | Vitamix 5000 Work Top Blender
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
Doesn't turn easily--sounds a bit labored
If the same problem exists when the pitcher is not on the base, the base needs to be replaced. It could be that the blade bearing is dry/rusty. In that case replace the blades. Either way, continuing to run the unit in this condition will fry the motor.
Jul 31, 2013 | Braun Blenders
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
Cuisinart model # SPB-6 (tx) leaking when unit is together, seal is in place, still leaking. Unit is not damaged, please advise.
Check if leaking at the bearing for the blade.
If the bearing has worn, dis-assemble and coat shaft with food-safe grease and re-assemble. Also coat the seals with the grease.
Sep 09, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Osterizer blender problem
Is the black plastic part, seal, and glass portion snugly fitted together? If so, it's likely that the black plastic part isn't making contact with the pin. On mine I have to turn it about a quarter turn to lock it to the motor/ drive pin.
If I have a hard object such as ice cubes too firmed placed in the blender against the blade and the glass, I shake the container to loosen the materials and reseat it onto the drive pin as mentioned above.
May 09, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Blenders Logo
231 people viewed this question
Top Russell Hobbs Blenders Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
