Question about Reddy Heating & Cooling
Runs a minutE and shuts off reddy heater 70,ooo btu 15 years old
Posted by Kina Jolly on
Tom Chichester
    Top Expert:
  • Reddy Master
  • 60,163 Answers
After 19 years of service, your Reddy heater probably is ready for replacement.
Posted on Nov 16, 2020
5 Related Answers
bluegreenash
Gareth Cockram
  • 661 Answers
SOURCE: reddy heater won't stay on
sounds like a Thermal Cut-off this is a small sensor that detects if the heater has ignited properly, sounds like this sensor has failed and the heater shuts off to prevent from gassing anyone
Posted on Nov 02, 2007
Anonymous
  • 19 Answers
SOURCE: 50K BTU Reddy Heater Trips Circuit Breaker
If the unit lights Check the photo cell this can be done with an ohm meter and good light. Should have continuity in light.
Posted on Mar 02, 2008
Anonymous
  • 625 Answers
SOURCE: 1000,000 BTU Reddy Heater
if you go to the desatech site you can get a diagram from them.
Posted on May 27, 2008
Anonymous
  • 540 Answers
SOURCE: Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Posted on Dec 22, 2009
Anonymous
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
Have a Reddy Heater 55,000 BTU unit, when plugged in it will run for about 5 minutes or so and then shut off.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 11, 2011 | Reddy Heater-30-55,000 BTU Variable
Heaters runs for a few minutes then shuts off.
was working fine refilled it and now it will run 5sec. and kick the breaker on it.It's an old 80's model 35,000 B.T.U. I cleand the photo eye with a cloth no change. Any solution's
Jan 29, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Runs for about 15 minutes then shuts off .
I believe the pump setting is 6.0 for the 155 BTU model. I will know more after tonight, we are using a Reddy Heater 155 unit tonight at church. I will look on the side panel and see what the PSI should be for the pump pressure and respond either tonight or tomorrow.
Feb 04, 2009 | Reddy Heater-30-55,000 BTU Variable
115000 btu ready heater/ about 3 years old from home depot/multi fuel
I would try cleaning the flame sensor, use a Qtip slightly moist with ispropyl alcohol. it's a rubber boot about 2in. long faceing the combustion chamber with two wires.
Jan 15, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Heating & Cooling Logo
118 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
