Question about Fujitsu Heating & Cooling
Fujitsu Inverter Nocria room air conditioner ceiling room type AWYZ14LBC: how can I access the drain in order to rince it ?... can I blow it through with a compressor from outside ?
Posted by Yves Winand on
5 Related Answers
Anonymous
  • 105 Answers
SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Posted on Jul 15, 2007
Anonymous
SOURCE: Ac conditioner stopped blowing
Compressor outside runs but no air blows thru the ducts inside..maybe a relay WERE IS THE RELAY AT
Posted on Aug 15, 2008
Anonymous
  • 25 Answers
SOURCE: My CV-13NH portable type room
If its blowing air, but not cold, the compressor isn't engaging. There are many different possibilities on this.
Bad compressor, unit out of gas, bad run capacitor, etc, all could cause this, even a bad control panel.
Hope its something simple.
Greg.
Posted on Aug 18, 2008
Anonymous
SOURCE: Fujitsu wall mounted air conditioner.
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Posted on Jan 23, 2009
Sparky2012
Sergio Shamshoian
  • 102 Answers
SOURCE: I have a TCL 2.5hp split system air conditioner
I will star checking freon pressure but you going to call an HVAC company to do that. Please turn it off or you will damage the compressor, if is not already.
Posted on Dec 06, 2009
My home base portable air condition blow cold air for short period I have put the temperature 16° if it blow cold air small then it will cut off and blow warm air and the room temperature is always at 30°...
http://www.royalsovereign.com/customer-support/faqs-frequently-asked-questions/portable-air-conditioner-faq.html
Why does my portable air conditioner cool for a short period of time and then turn off?
Have you extended the exhaust hose with another? The unit can ONLY be used with the included exhaust hose (dryer type exhaust hoses will cause the unit to over heat).
How close is the unit to the wall? If the unit is only inches away from the wall and you are running the exhaust hose out a window, more than likely their exhaust hose bend is at 90 degrees which restricts air flow. In order for the unit to run more efficiently and not overheat, it should be at least 1-1/2 feet away from the wall and the exhaust hose should not exceed more then a 45 degree angle.
Are you exhausting the unit out a hole in the wall? If so, are you using a flap vent on the exterior of your home/office? The flap may be too rigid and not open continuously. The compressor is not strong enough to push the air through and therefore will only run for a short period of time before overheating and shutting off. You should take the flap off the vent and replace it with a piece of screening.
Are you venting it into a ceiling or basement? Does the ceiling or basement have ample ventilation? If the ceiling or basement does not have a way of pushing the heat from the exhaust to the outside, the unit will work for a short period of time and then eventually overheat and shut off. Portable Air Conditioner FAQ Portable Air Conditioner Frequently Asked...
Apr 24, 2018 | Heating & Cooling
I have a Fujitsu air conditioner, model # ASUI8CI serial # ACA010576. It drips water into the room from the right side. After switching off the air conditioner and wiping the water, I switch it on again...
chances are either the unit is not level or the drain hose is not pitched properly going through the wall when water is leaking is there water coming out of the hose outside
Jul 11, 2011 | Fujitsu 24R1 Air Conditioner
Fujitsu Inverter ASTA09LCC Where is the drain tube located? The air con is leaking water and I believe drain may be blocked.
It is directly behind & thru the wall to outside next to the refer. piping.Everything goes outside thru a 3" hole. tube should b there.Blow it out.good luck
Mar 12, 2010 | Fujitsu 18C1 Air Conditioner
Central air conditioner leaking water somewhere. Water is going through furnace filter (furnace filter is wet) and ductwork and wetting the ceiling below. What should I look for?
look for a cover that covers the a A coil.take the small 1/4 in screws out and carefully remove the covers or cover if you have access do both sides. my basement has enough room to get to both sides. my house tlr you can only do one side. look for a drain hole blow it out with a air hose or garden hose run a wire if you have to.
Aug 01, 2009 | Heating & Cooling
Condensate overflows frequently.
Your drain tube is usally under the coila and is sort of hard to access it anyway. There are two things you need to do 1st take a wet/dry vac and hold the hose on the drain tube which will **** out any type of blockage there is (mostly algae) 2nd you need to get some treatment tabs from an a/c supply shop that all you do is place one of these tablets in the drain pan and it will prevent the buildup of algae therefore preventing your clogging issue. Good Luck
Dave
Jul 23, 2009 | Fujitsu 18C1 Air Conditioner
Adjusting thermostat temperature
nope. Try bouncing the air off the ceiling instead of pointing it towards the floor. You know the vent grille should be adjustable. The air is just recirculating back into unit and short cycling stat. Create a barrier between supply and return!
May 27, 2009 | Heating & Cooling
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu air conditioner - too much humidity
This can happen if the unit is too small for the room. Going by the model number I sounds like a big unit. I would also try cleaning the filters. Also set the temperature higher.
I take the time to help and answer your question so please rate me
Thankyou
Mat
Jul 02, 2008 | Fujitsu 18C1 Air Conditioner
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
Dan Webster
Dan Webster
jdthefixer
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
