Ovens Logo
Question about Belling Ovens
Using my belling oven IB609FV - Belling Ovens
Posted by lisa stratton on
Belling oven wont heat on any setting
Check if the timer is set? If that is okay, a failed element is the most likely cause. Disconnect the leads and check continuity with a test meter.
Belling Oven is Not Heating Up You can test whether your Belling oven is heating up correctly by turning the oven on, setting the temperature and letting it sit for five minutes. If the oven cavity is not hot when you open the door, it is likely that your oven element is broken.
Belling Oven Not Working? Here's How To Fix it
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Belling 492 bl short out when oven turned on
Sounds like the oven element is broken, replacement at
http://www.elementreplacement.co.uk/belling-elecr11budget-332-p.asp
Check dimensions with the one shown
Fan oven option not functioning on main oven, its a Belling synergie multifunction oven, about 5 years old
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
2helpful
Belling builtin electric cooker formula multifunction double oven think 488BH no instruction book dont know how to use the timer and different parts of fanoven etc.
get manual here
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
good for 60 days only
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
