Question about Laser Office Equipment & Supplies
I need a printer manual for my laser printer. Model# HL-L2370dw. How to download please.
Posted by Larry madzelan on
The Spaminator
  • Laser Master
  • 535 Answers
5 Related Answers
Anonymous
  • 21 Answers
SOURCE: Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Posted on Feb 11, 2008
Anonymous
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Posted on Mar 22, 2008
Anonymous
  • 148 Answers
SOURCE: Want to download installation details
If you go to this web site you will find the drivers and details for that printer. http://solutions.brother.com/hl1430/
Hope that helps...
Lbcoaster
Posted on Feb 27, 2009
Ekse
  • 13434 Answers
SOURCE: where can I get brother hl-2030 LASER PRINTER DRIVER
Hey,
The brother drivers and software require for the machine is available at
http://www.brother.com/E-ftp/info/index.html
Let me know if you need anything else.
Thanks,
Ekse
Posted on Mar 05, 2009
Nicolas Martin
  • 6 Answers
SOURCE: lost instalation cd for brother HL-2170w laser printer
So far as I can tell, the actual wireless setup software is not available for download at Brother's web site. The part number for ordering a replacement disk at brothermall.com is LU2442001.
Posted on Apr 13, 2010
I want to download brother hl-2040 laser printer driver
You can download the Brother printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.brother.com.au/ProductsSolutions.aspx
Feb 12, 2013 | Brother HL-2040 Laser Printer
I just bought a Brother HL-2270DW Laser Printer and it says it can do two sided printing. How do I do that? I don't have a manual - it just came with a Set up Guide. Thank-you.
First you can download the manual here : http://www.iusermanual.com/printer/brother-hl-2270dw-printer-manual.htm
Usually you need to enable DUPLEX option in the printer's managing software...
Jun 18, 2011 | Brother HL 2270DW Laser Printer
Need a driver for Brother HL-2140
You candownload the Brother printer drivers from their support WEB site. Please clickon this link and select your model printer to download :-http://www.brother.com.au/ProductsSolutions.aspx
Dec 21, 2010 | Brother HL 2140 Laser Printer
I need driver to install my Brother HL-P2500.How can I get driver for Brother HL-P2500. Thank you very much Thongchai
Nov 15, 2010 | Brother HL P2500 Laser Printer
Have mislaid my HL-2142 manual and need to install new toner cartridge . . . I'd be grateful for some help please.
All brother manuals and software is available for free download from their website - go to www.brother.com , and select your country.
Sep 30, 2010 | Brother HL-2040 Laser Printer
Brother HL 1280
is the actual model is Brother PT 1280 .. it';s a labeling p-touch..if yes..then you can download the user manual here...
http://www.brother.com.my/my/productDetail.asp?model=PT-1280&Rnum=241294
May 24, 2010 | Brother HL 1260e Laser Printer
Need installi
here is the procedure to install your Brother HL-2140 laser printer and drivers
Click here to see the manual and download the drivers
Click here
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
Mar 20, 2010 | Brother HL 2140 Laser Printer
Need to install a Brother printer Hl 5050.I lost the disc.
copy this link, select your country, and your off to the races:
http://welcome.solutions.brother.com/bsc/public/midlink3.aspx?prod=hl5050_all&lang=all&src=DOWNLOAD
*please rate me:)
Mar 17, 2009 | Brother HL 5050 Laser Printer
Top Laser Office Equipment & Supplies Experts
efs_perpends
efs_perpends
ADMIN Canada
ADMIN Canada
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
