SOURCE: reddy heater won't stay on
sounds like a Thermal Cut-off this is a small sensor that detects if the heater has ignited properly, sounds like this sensor has failed and the heater shuts off to prevent from gassing anyone
SOURCE: I have an R50 Reddy
If the heater runs good & smells good while its running, but shuts down for no apparent reason, then most likely, you have either a bad Safety Control HA3003 (reset) or a bad photocell HA3019.
But, don't rule out simple problems like:
(any of the following can cause a flameout condition, in which case the photocell will shut the unit down. This is where trouble shooting comes into effect).
troubleshooting tips
SOURCE: Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
SOURCE: Reddy Heater keeps shutting down
I tried to go to www.desatech.com and you cannot buy parts on that site anymore. I can get my Reddy Heater parts at www.masterparts.net.
Check for power to fan motor.....if there is power and motor does not go then the motor is bad...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
heater...
Reddy
Torpedo
heatman101
