Tablets & eReaders Logo
J
Joanne Galliher Posted on Jan 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the enter key on Tablet 4gx Enhance - Tablets & eReaders
Frejus Gnanvossou
Level 2:
Novelist:
  • Expert 81 Answers
  • Posted on Jan 21, 2023
Frejus Gnanvossou
Expert
Level 2:
Novelist:
Answers
81
Questions
0
Helped
8918
Points
111
The location of the enter key on a Tablet 4gx Enhance may vary depending on the specific model and manufacturer. Some tablets have a physical enter key on the keyboard, while others may have a virtual enter key on the on-screen keyboard.
You can check the manual of your tablet or do a quick search online to find the specific location of the enter key on your device.
If your tablet does not have a physical keyboard, you can find the enter key on the on-screen keyboard. It's usually located on the right side of the keyboard, next to the spacebar.
T47B Tablet how to unlock screen forgot code
Hi Mate,
  • On the unlock screen, enter your unlock pattern
  • After five attempts you'll be asked to wait for 30 seconds. Tap OK
  • If your phone display goes off, tap the power button and unlock your screen
  • Tap Forgot pattern? If you haven't set up a Google account you won't get this option, instead you'll need to reset your tablet
  • Enter the username and password of your Google account, tap Sign in
  • You'll be asked to create a new screen unlock pattern. If you don't want one, tap Cancel
To reset your tablet:
  1. Turn your tablet off
  2. Hold the volume down key
  3. Turn your tablet on
  4. Using the volume down key, highlight Wipe data/factory reset and press the power key to select
  5. Press the volume up key
  6. The reset is now complete.
Note: Resetting your tablet will clear all the data stored, data that's stored on your SIM is safe.
Cheers!!
User guide for Telstra Enhanced Tablet 4gx
try this:
http://www.ztemobiles.com.au/downloads/User_guides/A462_Help_1.0.pdf
2answers
I have a 10inch Tablet that my son put a password on but has forgotten the password. Is there anyway to reboot the tablet without knowing the password?
It's hard to tell you exactly how to do this without knowing which tablet you have. I'm guessing that it is an Android tablet and some of them (if you linked them with a Google account) will let you unlock them remotely through Google. This will have to be done by entering in the wrong password several times and then it will prompt you to try your Google account.
If that doesn't work you will most likely have to perform a hard reset on the tablet. Understand that doing so will wipe any personal files and reset it to the same state it was when you pulled it out of the box for the first time. I would recommend connecting your tablet to your computer and downloading any pictures or music you have on it first.
To reset the to reset the tablet some tablets have a small pin hole located on them that you can insert a paperclip into to reset the tablet. Some tablets will let you enter a development mode by holding down the volume-up key and the power key for several seconds. This will let you reset the device to factory settings.
How to get my tablet working? it's on speach back for blind person. screen not opperating when i touch
Here are some fixes:
1. System Settings ' Language and input ' Speech ' Text-to-speech output and turned off "Driving Mode".
2. settings > accessibility > installation of webscripts (turn it off)
3. Setting >Accessibility >Enhance web Accessibility put if on "do not allow"
Good luck
Sccreen says all systems, ie, keyborad,google etc have stopped
Most tablets available nowadays are Android-based ones. And most of them can be "factory reset" to leave them as brand new.
First, understand that if you continue, all the information you already added to your tablet will be erased. If you have any info you need to retrieve, please, do not go on and try something different, OK?
All right... Let's go on... The best way to know how to factory reset (or "hard reset", as it is also called) your device is to check in the Internet if there is already a description of the whole process. Assuming that you have a Samsung Galaxy Note 8 tablet, search in Google for "how to factory reset a Samsung Galaxy Note 8 tablet?" Follow the instructions and you will have your tablet running as if it had just been taken out of its box!
If you cannot find the instructions for your specific device, you could, then, try to check if it can enter recovery mode. First, completely switch off your tablet. Then, press at the same time and maintain pressed the "Power" button and the "Volume Up" button and wait for the device to power on, when you can release the keys. An "Android System Recovery" page should appear. If that is the case, you can navigate through the options using "Volume Up" and "Volume Down" keys. Go to the "wipe data/factory reset" option and activate it, pressing the "Power" button. Your tablet should reset (it will take a while).
If you didn't enter the reset page with those keys, repeat the process, this time pressing "Power" and "Volume Down" keys (different tablets have different combinations of keys to enter recovery mode.)
Hope you may find this information helpful!.
15helpful
2answers
How do i reset my kurio 7 tablet my daughter forgot the password
I FORGOT THE PASSWORD FOR PARENTAL CONTROL OF THE TABLET SMARTB JUNIOR
I cannot acess the internet on a 7 inch sylvania tablet
You sure you enter the right information? Try to connect with another device like a laptop? (be sure you remove your wifi connection data, so you need to re-enter your WPA(2) key)
If this works on another device, than try to connect with the tablet. Maybe you can choose which security protocol the tablet should use, either WPA or WPA2 for example.
9helpful
How can i enter the bios environment on toshiba portege 3500 tablet pc
hold the "esc" key presed during boot, and then pres the "f1" key and you enter to the bios
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
