Question about LG Dishwashers
LG Dishwasher turns on by itself but does not start washing. Does this a couple times a day. LDF7811ST/01
Posted by mike luciano on
Tom Chichester
    Top Expert:
  • LG Master
  • 56,001 Answers
The cycle selector is erratic. Possibly defective if you have had the machine for awhile.
Posted on Jan 19, 2019
5 Related Answers
Anonymous
  • 60 Answers
SOURCE: ldF7811ST LG DISHWASHER
LE stands for "Locked Motor". It means the main pump motor is bad.
Posted on Dec 20, 2007
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: i have an lg dishwasher mod#LDF7811ST, get error codeIE, changed the inlet valve, machine worked once then got IE error code again. Any suggestions?
If you are getting a IE or similar error on your LG dishwasher and have not been able to solve the problem using information based on that code, check the serial number of the dishwasher. If the first three numbers are between 501 and 702 you may have this problem:
The black mastic sound insulation material inside the dishwasher door can soften from the heat inside the dishwasher, allowing the wires inside the door to become embedded in it. If this has happened, the insulation on the wires can soften and begin to dissolve, resulting in shorted or broken wires. This may cause various error codes which may send you on a wild goose chase.
Take the screws out of the door and inspect the black insulation and the wires. If any wires are embedded in the black mastic, you may cut them and bypass them with a new section of wire, then make sure to add an insulating material to separate the wires from contacting the black mastic. In severe cases, the inner door panel must be replaced (they no longer use that type of mastic) and the wiring harness for the dishwasher would also be replaced. (a set of all the wires and plugs).
Posted on Apr 29, 2009
Anonymous
SOURCE: lg versa shuts itself off couple of times a day
There is a shock sensor in the phone and any slight jarring will turn it off to protect the circuitry (if you drop it good)... it may be annoying but it is a decent feature.
Posted on Oct 05, 2009
Anonymous
SOURCE: LG dishwasher ld14aw2 error
G'day
I had the same problem. With the help of a friend of mine we carefully pulled apart the dishwasher until we got to the pump.
In this location we found a small piece of white plastic had appeared (about one quarter the size of a 5 cent piece) and this was obviously stopping the impeller blade from spinning.
Once this tiny piece of plastic was removed and the dishwasher was reassembled, it now works like a dream.
Hope this helps someone else.
PS. a normal handyman/girl can do this, just take your time and carefully pull it apart, loosen the bottom, flip it over - so that the base unit can be assessed and then you can assess the pump and whatever problem lies within.
Posted on Mar 20, 2010
dennis bullard
  • 4090 Answers
SOURCE: I have a LG 42LD 550 just got it, couple day, it
Yes its faulty. This is not me being funny. The 42" TV has had many faults and weas under recall. LG does not mean good life. It means lotta garbage. If this is new take it back and have it replaced. Preferbaly with a different brand. If it was second hand it has to have minimum guarantee and be covered up to 7 days for colling off and trial period.
Get it back fast, the repair cost is sky high ( $600)
Please rate my help++++Thanks for using FIXYA
Posted on Jun 10, 2010
My wm2455h turns on by itself and after some time, it turns off. What is causing this>
It seems that the Main Control Board of your washing machine is playing up. The fact that when you unplug the machine from the mains, the main control board resets itself and you are able to start the machine points in this direction.
Nov 17, 2014 | LG WM2455 Front Load Washer
No power at. Maybe the fuse blew. Is there a fuse? If so how can I find it . Lg dishwasher model LDF7811ST/01
Don't believe there is a fuse. Before you dig into the dishwasher check the outlet that it was connected to. Make sure the wiring didn't come loose from there, or that the cord to the dishwasher isn't damaged.
Nov 28, 2012 | Dishwashers
Im receiving an OE error code on my LG Dishwasher Model LDF7811st. The machine runs for a little bit and then it dings a few times with the "OE" code and stops running. HELP please
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 21, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Parts for LG Dishwasher take weeks to get.
you could order direct... maybe quicker http://www.lg.com/us/support/parts/support-find-parts.jsp I got my part in 3 days
Apr 09, 2010 | LG 24 in. LDF 7811 Stainless Steel...
I have an lg ldf7811st and the bottom arm will not turn. I purchased the part 1267558 (motor assembly, vario spray valve) to repair it and I need instructions on how to install this part. Please advise.
you need to uninstall dishwasher and tip it backwards on the bottom of the dishwasher you will see a square panle remove the 2 screwsand replace the part then proceed in revers to put together
Mar 26, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
LE error message on the panel
Depending on the serial # of the dishwasher it may need a new wire harness and inner door liner.
LE is a motor circuit error.
Contact LG @ 1 800 243-0000 they may help you out.
Jan 15, 2010 | LG Washing Machines
ERROR CODE "TE"
The MOSt common reason for a "tE" error code is the temperature of the hot water from the hot water heater is greater thant 145 degrees (F)
Adjust your hot water heater down and measure the temp at the kictchen tap.
Good Luck!
Aug 26, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG Dishwasher LD12AW2
You've done every thing the way I would of done it but check the float switch it is located in the front of the tub near the door if this is open it wont allow power to go to the solenoid see if your getting power across this switch and let me know what you find out god luck
Jan 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LdF7811ST LG DISHWASHER
Dec 07, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
112 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Bill Johnson
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
