SOURCE: Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
SOURCE: jenn air Mdl#jcd2389ges Very slow water dispenser
You will probably find that if you have a water filter in your model refrigerator that is is clogged. Replace the filter and voila, good flow again. You probably also have small or hollow or chip ice cubes as well, if your filter is clogged.
To save the cost of the filter you would need to check to make sure you are getting strong water flow to the solenoid valve located in the bottom rear of your refrigerator.
I hope I helped, supertechks
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
[email protected]
