ViewSonic VG2230WM LCD Monitor Logo
Posted on Aug 05, 2009
Vg2230wm monitor Will not power on
My viewsonic vg2230wm monitor will not power on. The power indicator light is very dim and barely visible after plugging in the monitor. When you push the power on button nothing happens.
pudster11
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Aug 05, 2009
pudster11
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
5615
Points
27
Probably your power supply. Is it a cord direct from plug in for is there a box between where you plug it in and then a small round end that goes into the monitor. This would be the good news. If it plugs in direct then that means the power sopply is in the monitor itself which means more expensive to fix
  • amymade Aug 17, 2011
    I have this issue with the VG2230wm monitor as well. The power indicator light will turn on blue for only a second, then it dims down to blue/orange, then completely goes off. The screen is completely unresponsive. I tried a new power cord that I know works, and it didn't turn on.
Removing back panel of a viewsonic monitor
There are almost always plastic clips along with the screws. I'd recommend buying a plastic pry bar. You can google for them online and they cost $1 or so.
Viewsonic vg2230wm - the screen is blank when the computer first boots. I have to turn the monitor power switch on/off several times before the screen turns on, then it is fine.
Check your VGA (Visual Graphic Adapter) connector from your C.P.U (Central Processing Unit) to your monitor if it is intact. If it is intact , replace the VGA cable first. Then if the problem still persist check for the VGA driver in the device manager if it is correctly installed. If the problem persist try and send mail to me on [email protected]
Cheers.
Engr. Adewumi I.O
Screen is dimmed down can nor switch on
Unit has a hardware failure and needs repair or replacement.
2answers
VG2230WM (Black, Gray) LCD Monitor: Will not power up, no LED power light...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
2helpful
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
1helpful
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
