Question about Andis Health & Beauty
I own a Andis Envy and Andis Masters. For those who don't know, they are hair clippers. With the Envy, Everytime I cut hair, the fade lever closes the blade if I have it open, I checked the screws for the lever and they are tight so what could it be? Also with the Masters, I maybe tightening the screws to tight but the outer blade moves making the blade crooked once I turn the clippers on.
Posted by Henry Thillet on
AndreTheBarber
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Ok first u have to steady the blade vibration. There are typically to dials on THE SIDE of the Masters, they adjust the vibration and angle is blade. Grab a screwdriver (usually a flathead) and turn on the clippers. I usually adjust the top one until the clipper gets quietest. This will steady the vibration. Then the bottom dial will adjust to more to the left or right—center the blade as much as possible (while clippers are running) clippers should steady and be more quiet— then go back and fine tune that top dial. Ok, now the clipper is running at its optimal adjustment. Turn off—Now loosen the blade screws very slightly and move the top blade to match the new angle of the moving blade... retight tge bkade while making sure blade doesn’t move while retightening the blade screws. test the clipper by turning it on- the blades should be even wether clipper is on or off. If not, very slightly loosed screws and fine tune the blade angle and retighten. They should stay straighter now when running.
Posted on Jan 27, 2019
medypharma2148
    Sergeant:
    New Friend:
  • Andis Expert
  • 176 Answers
Buy cenforce 100 price Online is used to treat erectile dysfunction (ED). ED is the inability to get or maintain. Sildenafil citrate is the active ingredient in Cenforce. your most reliable Trusted online pharmacy Medypharma. Buy cenforce online, cenforce 100 price, cenforce 100mg review from Trustedsite.
Posted on Jan 17, 2019
1 Related Answer
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: when i cut hair my andis master clipper seems to
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Posted on Jun 23, 2010
My adjuster on my clippers wont stay still, everytime i cut on the clipper the adjuster on the side wiggles and moves to the top..how do i fix this
Take the upper blade off of the clipper, there will be four (4) screws which secure the adjustable part of the lever to the clipper. You can tighten these screws and that will control how much resistance you get when adjusting the lever.
Feb 21, 2011 | Andis 01690 Hair Trimmer
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
Jun 19, 2010 | Andis 01690 Hair Trimmer
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Jun 08, 2010 | Andis 01690 Hair Trimmer
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
My Andis Masters
tention is probably to tight, or blade needs to be realigned
Mar 11, 2009 | Andis Outliner II Hair Trimmer
How to replace the cord on my andis fade master clipper
In order to replace cord,you'll need a sortieing gun,electrical tape, disassemble cord cut sorter-ed end and  resorter.
Jan 09, 2009 | Andis 01690 Hair Trimmer
Health & Beauty Logo
54 people viewed this question
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
