SOURCE: LED display not working
Did somebody use the control lock by accident. Here is how to disable it. Hopefully it will work: The Control Lock feature shuts down the control panel pads to avoid unintended use of the oven. The Control Lock feature may be used either when the range is in use or turned off (for example, during cleaning). To lock/unlock control: Before locking, make sure the oven, the timer, and Timed Cooking are off. Press and hold the START pad for 5 seconds until ?CONTROL LOCK? appears on the display. Repeat to unlock, and ?CONTROL LOCK? will disappear from the display. Hope this helps Jason
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
SOURCE: I was setting the clock
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
SOURCE: stovetop works-oven does not work. all the lights are on but no response
check your oven element
SOURCE: my kenmore oven's led display works, but will not heat
pull stove out and check the volts either on the plug or terminal block on the stove where the wires are terminated. check the terminals marked L or line at the same time should have 240 volts if not your breaker which probably is a 40amp will need replacing
