Question about Smeg Kitchen Ranges
I can still manually light the burner with a match/lighter though. Also the oven still heats up and works fine.
Mostly when you can light up the pits without the clicker, then that means that there is no power on the stove at all. Check the power cord running to it (which generate the sparks) and see if there is any damage to it.
Posted on Jan 16, 2019
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
SOURCE: Tappan gas stove,oven not lighting
i am unable to use my oven on my tappan gas range. every other part of the range works wonderfully. the oven just will not light
Posted on Sep 11, 2008
SOURCE: gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
Posted on Mar 21, 2009
SOURCE: Whirlpool GS465 stove top burners won't ignite
adjust air hoods
thumbs up
Posted on Aug 17, 2009
Dec 19, 2015 | Kitchen Ranges
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
May 20, 2010 | Frigidaire FGF316 Gas Kitchen Range
May 24, 2010 | Frigidaire FGF316 Gas Kitchen Range
May 12, 2010 | Brown Stove Works TM210-3 Gas Kitchen...
Apr 25, 2010 | Smeg 40 in. PU106 Gas Cooktop
Apr 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
Mar 05, 2009 | KitchenAid Kitchen Ranges
Jul 18, 2007 | GE Profile JGSP48 Gas Kitchen Range
128 people viewed this question
