Hello, I think that your drain pump is blocked of is faulty. You will need to drain the water from the machine, remove the drain hose from the drain outtlet on the wall. or sink unit. Once you have done this check that the pump filter ( if fitted) that it has not clogged with fluff or other debris, If that is not clogged, you will need to look under the machine and check the hoses from the drum to the pump for items like flimsy underwear, socks, or other small items, these can slow the water flow, stop it, or stop the impellor on the water pump. If that is not blocked. check that the drain hose to the domestic outlet is not blocked, as sometimes if you live in a hard water area, it can block with calcium deposits. I hope this helps?
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
SOURCE: Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
SOURCE: Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
SOURCE: how to reset my washing machine (electrolux)
my electrolux EWT606 will not spin. it drains and then just wont go into spin cycle....no error messages it just beeps. can anyone help me please as i have kids with disabilities and NEED to wash!
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
