Plasma TV's are no longer available. Even if you decide to repair....at minimal you will need to replace three boards. Power supply, buffer boards and sometimes a Y board. At its best it may operate for three months and go down. This TV has served its purpose. Shop new. Thanks for asking, Matt of Martins TV Repair.
SOURCE: No Picture, sound is all static
CHECK YOUR VIDEO INPUTS. THE HD SIGNAL IS TAKING OVER ALOT OF THE ANALOG SIGNAL.MAYBE A STRONGER ANTENNA OR ADJUSMENTS MIGHT WORK AS WELL.
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
SOURCE: No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
SOURCE: lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
This issue is a
common, but hardly talked about from LG. Your tv is probably 1 or 2 months out
of warranty, and now you're hearing a series of clicks. After weeks of fighting
with LG to replace my tv, i decided to fix it myself. i'm proud to announce
that my 50PK540 is now working. want proof?
Take a look at the video i posted on youtube, then you will have a
better understand why your tv is clicking... I'm also selling the repair kit
for this power supply board on ebay now.
LG power supply Board model number EAY60968801. With anyone of these PCB
# EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 with the parts if this kit, I've also fis
several 50PK750 models, Some clients have send me their broken power supply
board, so I can do the repairs. Please Make sure that you've already gone
through the process of troubleshooting and testing your tv's power supply board
before making any purchases.. I recommend that you get a tv tech to check it
out, because every tv is different. Email at [email protected] if you have
any question.and watch the video:
http://www.viewbix.com/v/LG-Repair-KIT-now-available-on-Ebay/8ec4bea5-1d91-4d23-8180-7e5214e6c8f6
