Question about Maytag Refrigerators
How do I reset a control panel on Maytag frig model number MFI2569VEB3. Display is flashing PEO OOO
Posted by Lynda Gray on
Jeff Sluss
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Program code is located on the serial plate
Press and hold the Door Alarm keypad.
Press and hold the Freezer Temperature Down keypad within 3 seconds.
Release the door alarm keypad and wait 3 seconds.
The control will display PE to indicate the programming mode.
Press the Freezer Temperature Down once more.
The control will display the current Program Code. This should be the same as the program code on the serial plate. If the code is correct, press the Door Alarm keypad for three seconds to exit.
Press the Refrigerator Temperature Up keypad or Refrigerator Temperature down keypad to change the digit value. The decimal point indicates the selected digit. Press the Freezer Temperature Up keypad to select the next digit. Once the correct program has been entered, press and hold the Freezer Temperature Down keypad until the program code begins flashing indicating it’s been saved. Exit the programming mode by pressing any key.
Posted on Jan 16, 2019
2 Related Answers
appldoctom
Thomas Malailua
  • 311 Answers
SOURCE: I have a Maytag model
i would unplug and start again,refer may be board.as you seem to know with out that code in there it wont work[been there done that]and you have to read carefully and do just as instructions say to pull it off.you can do it though. God bless ,tom
Posted on Jan 24, 2009
Anonymous
SOURCE: need reset code for maytag fridge MFI2266AEU. Just
My sticker is missing. What code do I use?
Posted on Feb 01, 2010
Why is it stuck on PEO OOO?
Did you change a control board? Most times this happens when you change the motherboard and its not programmed for that refrigerator what we're going to have to do is get your model number and there's a code below your model number inside the refrigerator get me that and I'll try to help you find the instructions to reprogram your motherboard
Dec 01, 2015 | Refrigerators
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
I have a Maytag model no: MFI2568AEB I replaced the HV Control board in the back, when plugged in the front panel now reads PEO OOO and the you cannot put your code in O3O2 all freezes, please help. Thank...
Jan 24, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerator not working
LOWER CIRCUIT BOARD
The controls for Models RM2612, RM2812, RM2652 and RM2852 are unique to these models. They
are NOT interchangeable with any other models.
If you suspect mismatched part numbers, compare the part numbers on parts to the ones listed below
to ensure a proper match.
The RM2612 with Serial Number 41900000 or higher will have Version III controls as original
equipment.
The RM2812, RM2652 and RM2852 should have only Version Ill controls as original equipment.
VERSION I
Display Panel 2932189.01
Power Module 2931842.02 or 2931842.03
Thermistor 2931863035
VERSION II
Display Panel 2932189.02
Power Module 2931842.02X
* Power Module has red plugs and a Red Dot on
the cover.
VERSION Ill
Display Panel 2932189.03
Power Module 2931842.04
Oct 03, 2008 | Dometic RM2652 Refrigerator
Control panel flashing
UNPLUG FRIG. FOR 3 MINUTE,THIS MIGHT RESET EVERYTHING AUTOMATICLY,IF NOT SEE IF YOU HAVE A CLEAR OR RESET BUTTON,PUSH THAT TO SEE IF IT RESETS,ALSO WHEN YOU GET A FLASHING BOARD IT'S TELLING YOU ONE OF THE FRIG.'S COMPONENTS MIGHT HAVE FAILED,LET ME KNOW WHAT YOU KIND,THANKS-MIKE
Jun 11, 2008 | Maytag Refrigerators
How do i reprogram my HV board?
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 SECS.-4.CONTROL WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Oct 26, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
341 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
