Question about Frigidaire Kitchen Ranges
I have a Frigidaire stove and I went to use the clean feature and it won't come on it turns on for a few seconds and then the light goes off what do I do to get this to clean
Posted by Sandy English on
ray gallant
    Top Expert:
  • Frigidaire Master
  • 68,584 Answers
WHEN IN DOUBT CALL A PROFESSIONAL REPAIR SERVICE IN MANY CASES WHEN PEOPLE USE THIS FEATURE THEY HAVE TOTAL FAILURE WITHIN A FEW DAYS SEEMS THE EXCESSIVE HEAT MELTS OTHER WIRING BEST TO USE A DRIP PAN TO CONTAIN SPILLS AND DO THE CLEANING THE OLD FASHIONED WAY ,BY HAND AND OVEN CLEANER.
Posted on Jan 19, 2019
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: FRIGIDAIRE GAS RANGE FGF378WCC
sl, because it't happening to both broil and bake the first thing I would suspect is the temperature probe. You should ohm it out. You can do this either at the board or at the harness connection in back. For the board, remove the back panel, there should be a 8 pin connector to the left of 3 relays. On the harness measure the resistance of the wires going to pins 1 and 2. On the shemantic it shows them being the 2 on the bottom. Should read around 1100 ohms at room temp. If you cant get a good reading on it there, Remove the probe from the inside oven, remove the screws and pull it out until the harness connector comes through, disconnect it and ohm it out from there. I don't think that both ignitors would fail at the same time so Im leaning toward the probe. Catriver.
Posted on Dec 11, 2007
Anonymous
  • 150 Answers
SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
Posted on Apr 22, 2008
Anonymous
SOURCE: frigidaire ceramic top self cleaning stove
Have you thought about reading the manual, it states that the heat goes off and on to maintain the proper heat while cooking, You should turn the burner off a few minutes before done because even on off the burner is still cooking while it is cooling down to go off. And you do not need to have as high of heat to cook that's what so great about this ceramic tops you save time and energy.
Posted on Jul 23, 2008
Anonymous
SOURCE: Frigidaire Self Cleaning Stove
Yes you have to set the timer. If it is like my stove/oven you have to set the time to start and the time to complete. normal cleaning 3 hours heavy cleaning 4 hours light cleaning 2 hours.
Posted on Aug 12, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: Frigidaire gas oven locked problem
you have a short in the Electronic Oven Control. if no error codes only two in this EOC
F1 or F3
Posted on Sep 13, 2008
Unlock frigidaire professional series
Good Morning Anonymous, thank you for your post!
Based on the symptoms you are describing, it appears that your Frigidaire range is possibly locked. Typically, the "Door Locked" light will glow until the Self-Clean cycle has completed or the oven temperature has cooled. However, if the issue continues, please confirm that the Oven Control Lockout feature was not accidently selected (on some models). If so, you can cancel this feature by pressing CLEAR/OFF and hold for approximately 10 seconds. The control will unlock the oven door and resume normal operations.
If the instructions above do not solve the problem, may I please have your model number? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can determine if your range is possibly experiencing other issues. Thank you - Z.
Apr 06, 2014 | Stoves Ovens
How do you relight the gas stove.
not knowing the year ,, there are 2 ways stoves light, pilot light and glow plugs, following the gas line into the oven itself, If it has a pilot light you will see the control for it,, just hold a match or flame to the end of it and you should see a button to push,, If you have a glow plug,, it should light after a few second of turning on the knob,, watch to see if there is a glow next to the oven burner if there is and its not lighting,, your thermo coupling may be bad
May 30, 2011 | Frigidaire Gallery 30" Self-Cleaning...
Stove door wont close
try shutting off power and then turn on..If this doesnt work turn on self clean again ,start it then after a few seconds cancel. This should tell the lock to release.
Mar 30, 2010 | Frigidaire FEF336BC Electric Kitchen Range
F1 llight on, oven locked, stove beeps every few seconds
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
John
Oct 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery Stainless steel convection oven professional series
i have a frigidare gellery oven i cleaned it and now my broiler an oven wont work
Jul 04, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
May 29, 2008 | Kitchen Ranges
Frigidaire stove door locked
I've had a similar problem - door is locked. If the door is open - locate the light switch and hold it in for a few seconds. Sometimes it makes a noise and resets the lock. Otherwise, push the Clean button and the Cancel button on front of oven simultaneously and hold for about 30 seconds. The ?locked? light should disappear. If it is working, you?ll hear a mechanical hum as it resets.
May 10, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
