Car Audio & Video Logo
Patricia Polster Posted on Jan 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My boss bv6656B will not show a2dp when I hit source. I only get radio and aux
Tommy Law
Level 2:
New Friend:
  • Expert 42 Answers
  • Posted on Apr 26, 2019
Tommy Law
Expert
Level 2:
New Friend:
Answers
42
Questions
Helped
12961
Points
112
It will not show that on list it can strem if BT is connected to phone https://www.bossaudio.com/manual/BV6656B_EN_UM.PDF
1 Related Answer
Anonymous
  • Posted on Jun 14, 2009
SOURCE: Aux won't work
Some radios have a place in the settings where you can turn the AUX off
I have a Boss BV6656B and I can't get my Bluetooth to connect, the SRC only displays Radio and AUX?
Page 9 of the manual says it goes into Bluetooth Search when you power it on, so get your phone searching and then power the radio on. Pretty much every Bluetooth unit I have come across needs a button pressed to send out the signal.
I don't like this mention of a 'Hands Free Kit' or that is says 'pairs to *most* mobile phones'.
Bluetooth Features:
Built-in Bluetooth technology for hands-free talking and audio streaming
Bluetooth Profiles Supported:
HFP: Hands Free Profile allows a hands-free car kit to connect to a compatible mobile phone
A2DP: Advanced Audio Distribution Profile allows high quality audio to be streamed from an audio device to the car stereo
Works with most Bluetooth enabled cell phones
Includes a built-in microphone for clear, convenient, distortion-free talking
My Boss BV 6656B radio keeps turning back on. It is in a grill system. Everything else works good. I unpaired bkuetooth and I hit source power button. It saya goodbye and less than 10 sec keeps turning...
Boss BV 6656B radio read the manual first. no really
and look for batteries inside that are dead first. always this FIRST.
a car radio RIGHT, posted to computers, and is NOT.
the Radio will have 2 power sources, most times.
1: ignition on.. ACC.
2: memory. (this must go to the car battery , hot full time wire in harness)and fused
if not wired right this will fail.
boy finding the install manual is a pain on this BOSS, users manual is useless, for that.. zero facts there but click rules..
what does Grill system mean,? google shows Zero hits. why use that word, dash? mounted, you mean?
it has a remote so remove its battery if they are weak
any remote on earth can go NUTS, (low battery worse of all)
ok you can remove all power to the car radio, all wires, power.
then wait overnite and try it then. (a level 1 reset on any thing electronic if batteries inside those out too)
most car radios have no battery, but BOSS id never guess.
the power button on the RAD has long press mode. use that?
>3sec long. it states.
the yellow wire is memory wire, remove that to reset radio.
red wire is ACC./IGN on wire main power remove both to reset radio.
I think i covered all ways to fix this problem..
remove power
replaced remote batteries first. as is the case always, first.
How do I go on aux mode on the Jcv kd-g401 radio
Should have an aux button or source button (src). If it does have a source button hit repeatedly until you see aux
Why is my screen blue when I use aux an play music on my phone on a boss BV9757B touch screen radio. I have already grounded my brake wire. Please help
That is a factory setting. On some models there is a video select button whereas you can change video to another input source. :)
Can't get aux cord to work
Try having the device(cellphone.etc..) hooked up to auxillary on its end.. then play music or whatever..then plug the stereo end in and try changing source then.. maybe the unit isnt switching because it doesnt think theres a reason to.. not kidding.. Ive seen this kindve stuff all the time from electronics..theyre so smart theyre stupid. Hoefully this works:)
I have a Bose Wave II radio. Never a problem until today. No sound from radio, CD, aux. Display works fine. Remote works. Have tried unplugging and plugging back in. Tried turning volume up, muting and...
in your boss amplifire system hardware problem in u try to mute and volume button please check aux port also if found no output sound then go boss service station there are some hardware problem
I dont know what botton on my kenwood to press to change it to the aux jack on the front
You have to turn the AUX on. Hit the source button till the radio goes in to standby mode. then press and hold the menu button.. toggle through till you find the AUX option, and set it to on. After that you should be able to just use the source button to select AUX
2answers
Sony cdx gt200
I HAVE A SIMILAR MODEL AND I HAVE TO HIT THE SOURCE BUTTON TILL AUX APPEARS MAY BE A RADIO MALFUNCTIO
4helpful
Put in new car battery, now can't get aux to work
Hi there
hold down the source button to turn off the unit (unit must be off)
now hold down the function button till it beeps once it has done this press the function button i think 3 or 4 times and you will get a message on your deck unit saying (aux - on,off) turn on and press the source button to turn the unit back on to the CD or radio now press source button2 or 3 times till Aux shows up (press means push it let it go) (hold means don't take your finger off button)
hope this solves your problem
VIDEO OK, AUDIO NOT WORKING
The aux or auxiliary is used for external audio source (ipods, portable mp3 player,etc) If you are watchig dvd movies, the sound should come from the dvd and not from aux.
Top Boss Car Audio & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
