Question about Bunn Coffee Makers & Espresso Machines
My bunn leaks, how can I repair it?
The model number is NHBX-B. The date code is 11Ch 1441
Posted by Maria Mei on
1 Related Answer
Anonymous
SOURCE: MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Posted on Mar 16, 2009
HOW DO I STOP A LEAKING BUNN COFFEE MAKER NHBX-B
Go to UTube - there are some good videos out there on how to fix this. You have to take the top off and clean the flapper.
Jan 25, 2015 | Bunn Coffee Makers & Espresso Machines
How to remove the top water resivour from a nhbx bunn coffee maker
lift filler led and remove 2screws on top of reservoir
Then remove 4 screws that hold the reservoir on an you should be able to lift it off
Sep 03, 2014 | Bunn NHBX-B Contemporary 10-Cup Home...
Bunn nhbx leaks water
Jun 30, 2014 | Bunn NHBX
I have a Bunn coffee maker with date code of 401406. It is almost 4 years old and still brews perfectly. The warming plate does not heat up any longer so the coffee will not stay warm after it is brewed....
The manual for this coffee maker can be found at this link:
http://manualheaven.com/assets/bunn-nhbx-b-contemporary-coffee-maker-manual.pdf
While the manual does not contain repair instructions, it does have some troubleshooting tips to follow if your coffee is not staying hot.
May 04, 2011 | Bunn NHB Coffee Maker
We have a Bunn model NHBX-B, s/n 143308CH that leaks out the bottom rear and trips the GFI receptacle. Any recourse? Thanks
Your brewer is still under the warranty. If you will call 800-352-2866 with the model and code date, we will send you out a new machine.
Oct 14, 2010 | Bunn NHB Coffee Maker
I have a bunn coffee maker the nhbx is the # it is leaking water from the resevoir
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
May 12, 2010 | Bunn NHB Coffee Maker
I have a bunn coffee maker the NHBX is the # it is leaking water from the resevoir
If you will locate the date code on the bottom of the unit and then call Customer Service, the machine will be replaced at no cost or if over 3 years old, at a reduced price.
Mar 21, 2010 | Bunn NHB Coffee Maker
I have a 10 cup Bunn NHBX which leaks around the spray head. Is there a repair kit available?
There is no repair kit but if the machine is still under warranty can be replaced at no cost. If out of warranty, we will replace it at a reduced cost. If you will contact Customer Service, we will be happy to assisst you with this issue.
Feb 14, 2010 | Bunn NHB Coffee Maker
Coffee Makers & Espresso Machines Logo
62 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
