Check battery
Would try in order:
1) Do you have power coming to the camera ie can you take pictures and see them? If not likely battery issue since no power. If a removable battery simply see if it charges fully and reinsert. If you are able to charge the camera with battery inside and a power cord, and it works then a bad battery.
2) For some cameras they have a butting next to the record switch on the back panel that you have to push and/or toggle. This is different than the push button switch on top used to take pictures.
3) If tried 1 and 2, try to toggle switch between display, taking pics and records several to see if it only works for display and taking pics. If so then an issue with the switch assuming digital camera.
This may mean that it is not working, or even broken. Take it to your nearest repair facility and get their expert opinion.
