Televison & Video Logo
Question about Astar Televison & Video
Astar model Ltv-32sb is just black screen, no sound but power light turns on. I've changed outlet and tried main power on bottom. it just turns on or off the light.
Posted by Melissa Newsome on
5 Related Answers
boonys
Boonys P
  • 21 Answers
SOURCE: Astar Plasma
I had the same problem... Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Posted on Feb 08, 2008
Jaime Hernandez
  • 2351 Answers
SOURCE: On my Sharp LCD TV a black empty box appears
You will need to find the close caption feature in the menu adjustments and turn it OFF. You should do it for all the individual channels that have it activated.
Posted on Aug 20, 2008
Anonymous
  • 9 Answers
SOURCE: Astar LTV-32ASB will not power on.
The power board is defectived, just e-mail me the power supply picture and I will help you go throuth the problem. [email protected] or call 323-767-6030
Posted on Jan 16, 2009
Anonymous
  • 187 Answers
SOURCE: seems as if LCD screen is not recieving any power, I have no picture or sound right now but can faintly hear speakers power up when I turn the unit on.
Mainboard damaged.
Posted on Jun 02, 2009
Jaime Hernandez
  • 2351 Answers
SOURCE: Astar LTV-2701 27
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
Posted on Jul 03, 2009
3answers
No Picture or Sound from ASTAR 32 inch LCD Television
There is Part Store having Astar LTV-27BG boards in stock. Please check out might help you to power up back your TV.
Regards,
LTV-32ASB ASTAR -BLUE POWER LIGHT TURNED TV OF AND ON TWICE- AND
Hello Sir,
I need more details for these problem,
Please call 323-767-6030 and I will go through with you for the astar tv, model LTV-32ASB.
No power no picture no sound Astar LTV 20PW
Hello friend,
Your tv can be fix, I am the right person could help you fix your tv.
please call 323-767-6030.
2answers
Astar LTV 2701 power supply
I have aquired an Astar LTV 2700 and believe parts are missing. Any idea where I can get the Schemetics for this tv. E-mail me please. [email protected]
ASTAR 19" LTV-bs/bg HD/TV
If you still can't reset your TV by holding the enter button please call my friend at 323-767-6030 he may help you go through it.
2answers
There is more than one problem with. A it could be the main board that finally gave out. B the power board in your TV is not work, and now you can see a picture. Depending on how it's connect the screen could be burn out. but just what type of light comes on when you try to turn it on. if the green light comes on and stay on then it has to do with the picture not the power if you need help narrowing down the problem you can call 226-2211 My E Discounts. I'm a tech and we work with a Astar TV from time to time.
1helpful
AStar Ltv-2701
It appears to be a power supply failure. In about 95% of cases is a defective power supply that causes the TV to behave as per your description.
If you need more info you can email [email protected]
1helpful
3answers
Astar LTV-2701 27
Screen goes black immediately after astar logo screen comes on
Top Astar Televison & Video Experts
Jaime Hernandez
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
