Find handset works by causing the handset, or handsets to beep when you push the button on the base unit, and until you find the handset and push the off button. If the handsets do not beep the batteries are probably dead.
We have a handset that flashes "Charging", and later, "Connecting", but it never connects. When the handset is removed from the charger the handset shows "Place in charger". By process of elimination I have determined that the handset has a problem. The problem is NOT with the battery OR charger. I hope this info helps you.
-Vector721
