Cameras Logo
Janni Seraidaris Posted on Jan 12, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My nikon Coolpix L340 says: Out of memory! The memory card has 32GB and I have taken some 9000 pictures. Do I have to buy another memory card?
Simon Atkinson
Level 3:
  • Nikon Master 3,933 Answers
  • Posted on Jan 12, 2019
Simon Atkinson
Nikon Master
Level 3:
Answers
3933
Questions
13
Helped
1070445
Points
14095
You have two main choices. Yes, you could buy a new memory card. But I find the extra small cards can be easily lost or misplaced.
A better method is to transfer the images from the camera to a computer or laptop. It is also possible to transfer the photos through the computer or laptop onto an external hard drive with a much larger memory as a back up. Then you can re-use the card you already have.
5 Related Answers
Anonymous
  • 9 Answers
  • Posted on Aug 21, 2008
SOURCE: Nikon coolpix 5700 shows no memory left after purchasing a new card & batteries
The largest CompactFlash card that Nikon approved for the 5700 is 256MB, which is what I'm using in my 5700. That's small by today's standards and you probably won't even find it in stores. I see some web sellers have 256MB cards for only $6 or so. Other commercial card sellers on the web claim that the 5700 will handle CF cards up to 1GB capacity. That's what I might try since online they're selling for as little as $8 plus shipping. Given that the 5700 was introduced in 2002, any cards bigger than 1GB probably won't work.
Anonymous
  • 423 Answers
  • Posted on Feb 23, 2009
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
Anonymous
  • Posted on Aug 07, 2009
SOURCE: Nikon Coolpix L4 Memory card problem
Original camera had capacity for 249 pix. After formatting camera to free up memory I only have memory for 9 pix
What gives?
Thanks
Anonymous
  • Posted on Sep 13, 2009
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Anonymous
  • Posted on Dec 26, 2009
SOURCE: Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
Nikon B500 camera. I put a new memory card in my Nikon B500 and the camera says 'card not present'.
Is it this type of card?
The B500 is compatible with SDHC and SDXC cards. That means you can use cards from 4GB all the way to the largest cards currently available. (at that time 128GB)
And is it less than 128GB?
Your Nikon Coolpix B500 Digital Camera is compatible with 16GB, 32GB, 64GB and 128GB SD, SDHC and SDXC memory cards.
https://www.google.com/search?q=nikon+coolpix+b500+compatible+memory+card
What size memory card goes in the nikon coopix500
The Nkon Coolpix P500 takes SD cards up to 2GB in size, SDHC cards up to 32GB, and SDXC cards, up to 2TB.
The Nikon Coolpix S500 takes SD cards up to 2GB in size.
How to recover accidentally deleted photo on Nikon Coolpix S6300
I also encountered the same problem with my Nikon COOLPIX P100. Fortunately, I found Nikon Photo Recovery software through Google search. It helped me to get back all the lost pictures and video. Read more: http://www.nikon-photo-recovery.com/ Best wishes!
1helpful
I took the memory card out of my coolpix 4600 and put it into a vivitar camera when i inserted the memory card back into my coolpix cannot get the camera to work or turn off
Did you take pictures with the vivitar camera and saved it on the same memory card? If so, that might be the problem. Delete those files taken by vivitar (copy them to your computer if it is important before deleting) then try the memory card again on your coolpix.
How much memory can a L22 handle?
It can handle as much memory as you throw at it, one SD/SDHC card at a time. SD cards max out at 2GB, SDHC cards max out at 32GB. When one card fills up, you can remove it and insert another.
Eventually you'll want to transfer your pictures to a computer's hard drive for printing, emailing, or whatever.
7helpful
2answers
Pictures taken with camera and no memory card inside how to
There is a copy option on the playback menu.
This copies to and from the memory.
Nikon Coolpix S550 memory card problems
Your camera uses a different filing system than the other camera...they are not interchangeable.
193helpful
2answers
Regards,
Lardzor.
Camera does not show taken ( saved) pictures
problem is in memory card...i think. try with cleaning memory card contacts. use pure alcohol and small piece of cotton to clean dust or other dirt. if this not help, try some card reader to transfer images from camera to PC. try also with some other camera. it's possible memory card is damaged and you can't do nothing. try reinstall nikon software on your PC.
My camera problem!!!!
open camer
remove sd card
locatre secure tab on edge of card
slide tab the other way
insert memory card
take pictures
the little secure tab is easy to inadvertently slide
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
