I am unable to access anything on my fire tv because the storage is all used up.
Put it in a pc then look for what you not want
Connect to PC with the USB cable is one option then use file browser to delete objects.
Installing an app to control the firestick on your mobile is another and probably the best as the apps not required can be completely uninstalled and deleted.
http://streaming-blog.com/amazon-fire-tv-stick-how-to-use-your-phone-as-remote/
SOURCE: Changing program source without remote
Do a web search for a replacement remote control. If you got the tv without a remote, then I'm guessing you don't have a manual either. Here's a link to a free downloadable manual.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e341b6ad1733d53ba32cb47caf24d013&q=Sanyo+DS19330
SOURCE: storage space
look in UAContents folder. IT's keeping a copy of every image you send via MMS. Delete those and you're set.
SOURCE: My HTC P4350 is running low on free storage space
The system have used nearly the maximum internal memory available: Storage: Total 33.45 MB; In Use: 32.80 MB; Free: 0.66 MB Program.
If you already deleted or moved to memory card your files, that means that the space is taken by installed application/games, or by files left over by previously installed applications.
Save all your files on computer and do a complete reset of the HTC, restoring system to factory settings.
SOURCE: Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
SOURCE: I want to unlock the child lock key on my LCD TV
Since this set like all others with the "child lock" require a code to be entered and the remote is what is used, I would say it cannot be done without the correct remote and the password.
