SEBO Automatic X1 height adjuster wheel seems to be slipping. When I switch on my SEBO in the upright position the brush up light lights. When I lower the handle I can feel the height adjuster wheel raise then slip down again numerous times. The brush down light doesn't light. Would replacing the entire height adjuster module cure this problem ? Thanks
SOURCE: Sebo X1 vacuum not working
The X1 has a servo motor with gear box, this is what adjusts for height. Either something has jammed it, or
it has gone bad. You would probably be looking at a $80 to $100 repair, that is if the servo is bad. There also is a computer controller circuit board which could be the problem.
