Anung sira ng tv TCL brand pag open ko merong picture at sound,but after 30sec nawawala ung picture pero may sound at hindi na muling bumabalik ang picture
2yrs pa lang ginagamit 42 inches
Posted by rene mendoza on
4 Related Answers
Anonymous
  • 928 Answers
SOURCE: hindi kasi ako marunong mag-lagay ng games or install man lang
ano ang maitutulong ko sa iyo. gusto mo bang i recover ang data mo?
Posted on Feb 07, 2009
Anonymous
  • 518 Answers
SOURCE: ayaw mag print out
cant quite understand the type of english used but if the cartridges have been refilled .. the mashine goes through a process of cleaning and realianing the cartridges.if one isnt working then jets have dried out and blocked,in the refil kit is a bottle of solvent,put a bit in saucer,put cartridge in so jets are covered and it will disolve the dry ink
Posted on Jul 05, 2010
Amado Petallana
  • 320 Answers
SOURCE: hello,, ahm ash ko lang kong
Please refer to the link below for the service centers located in Manila area.
http://www.samsung.com/ph/support/location/supportServiceLocation.do?page=SERVICE.LOCATION
Posted on Nov 04, 2010
tonyc6171983
Tony Curto
  • 246 Answers
SOURCE: pa help po please na child lang ng kapatid ko ang Tcl-21189U na tv namin eh wala pa namang remote paano kaya gagawin ko nabubuksan sya pero walang nag aappear sa monitor.
is this even english
Hindi magsisimula ang Honda TMX
Hi, Emil at ang karaniwang mga suspek ay:
1. Walang tangke ng gasolina.
2. Ang tangke ng gasolina ay may lumang patay na gas.
3. Ang tangke ng tangke sa ilalim na kontaminado sa ethanol na putik, dumi, tubig, kalawang, atbp.
4. Ang balbula sa supply ng gasolina / naka-off ang petcock.
5. Fouled spark plugs.
6. Ang baha ng sasakyan ay bunga ng sobrang paggamit ng mga mabulunan.
7. Vacuum hose sa gasolina supply balbula / petcock disconnected, nasira, basag, o pinched.
8. Ang balbula ng gasolina / petcock o filter ay naka-block.
9. Fuel linya sa karburator o balbula katawan pinched, kinked o hinarangan.
10. Carburetor Float stuck.
11. Ang mga iniksyon ng gasolina ay nagbara.
12. Ang mga iniksyon ng gasolina ay nananatiling bukas.
13. Mabilis na idiskonekta ang check ball stuck.
14. Compression sa ibaba 75 PSI.
15. Isang naka-stuck-bent-burnt valve.
16. Malubhang discharged o nasira na baterya ay dapat magkaroon ng 12.5 volts o higit pa at maaaring pumasa ng isang wastong "LOAD" test kung kinakailangan, maaari kang magkaroon ng isang cursory pagbabasa ng 12.5 volts o higit pa ngunit maliit o zero amperage ang baterya ay may sira at dapat mapapalitan, mabibigo ang mga baterya ng AGM sa sitwasyong ito nang higit pa kaysa sa lead-acid na mga baterya.
17. Suriin ang mga terminal ng baterya para sa pinsala o kaagnasan, lagyan ng tsek ang mga kable ng baterya sa "BOTH" para sa maluwag, nakakagambala, o sirang mga konektor, "INSIDE" at sa labas ng cable harness, magsagawa ng pagkabit ng pag-ikot ng pagsubok at suriin ang mga cable na may isang ohmmeter kung kinakailangan.
18. Loose o corroded wire connection sa likid o plug sa pagitan ng ignition sensor at ECM module.
19. Spark plug cable sa masamang kondisyon at shorting check para sa spark butas na tumutulo sa madilim, cable koneksyon ay maluwag o konektado sa maling cylinders.
20. Hindi wasto ang timing dahil sa isang sira na ignition coil, ignition module o MAP, CMP, CKP, O2, TPS, ETP, IAC sensor.
21. Nasira neutral, klats, kickstand kaligtasan switch.
22. Faulty fuel pump o fuse o relay.
23. Faulty o corroded run / stop switch.
24. Ang sensor ng ikiling ay nangangailangan ng pag-reset.
25. Ang sistema ng seguridad ay hindi nangangailangan ng pag-armas ng alarma ng isang pag-reset.
26. Suriin ang mga code ng problema sa engine.
Para sa karagdagang impormasyon tungkol sa iyong isyu at mahalagang "LIBRE" na mga pag-download na kakailanganin mo para sa pagtingin o pag-print mangyaring mag-click sa asul na mga link sa ibaba. Good luck at magkaroon ng isang kahanga-hangang araw.
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
Troubleshooting No Start Honda Motorcycle
Honda TMX 155 2013 service manual DOWNLOAD FREE FULLMANUALS COM
https://www.partsfish.com/page/oem-parts-for-honda
http://ourbumble.com/wp-content/uploads/2016/01/Honda-MSX125-Owners-Manual-Eng.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 06, 2018 | Honda Motorcycles
Honda tmx
Hi, Cedric Gusto ko pag-ibig upang makatulong sa iyo sa iyong engine o chassis ingay ngunit ko lang ipahiram ang aking bagong-bagong pares ng pakikinig tainga upang chief technician iyong lokal na dealer sa gayon siya ay maaaring dalhin ang iyong bike para sa isang biyahe sa pagsubok at magbibigay sa iyo ng kanyang propesyonal na opinyon at pagtantya tungkol sa iyong mga ingay at repair gastos. Kung ikaw ay isang maliit na short sa "drakma" at isang Dealership ay wala sa iyong listahan ng mga masaya na mga lugar upang bisitahin at pagkatapos ay marahil sa listahan sa ibaba ay makakatulong sa umamo ang iyong nag-aalala isip upang maaari mong gumawa ng kaalamang desisyon. 1. Bearings --- Screech 2. Sinturon --- Chirp 3. Brake Rotors --- BUZZ 4. Chain --- magpakalantog 5. Clutches --- Chatter 6. Cylinders --- PING 7. Fronk Forks --- kalabitin ang kuwerdas 8. Gears --- Whine 9. Head gasket --- Hiss 10. Hydraulic Lifters --- TAP 11. Pistons --- SLAP 12. Rear Shocks --- Squeak 13. Paglilipat Trans --- clunk 14. Solid Lifters --- tik 15. Starters --- CLICK 16. Pagkonekta Rods Go --- KNOCK-KNOCK --- kung sino ang doon, ito ay sa akin "KAMATAYAN" Good luck at magkaroon ng isang kahanga-hangang araw.
Apr 09, 2017 | Motorcycles
I have a bajaj wind 125, ganda ng takbo tapos bigla na lang pumalya then ayaw na umandar wala na kuryente sabi mg mekaniko gounded daw ksi pag nabody ground na ung ignition coil wala na sya kuryente pero...
Hi Eric, ikinalulungkot ko na hindi mo mahanap ang una at pinakamahusay na tool ba kayo bumili ng para sa iyong Bajaj ngunit walang pag-asa hindi para sa isang lamang $ 0 maaari mong i-download ang isa pa. Para sa karagdagang impormasyon tungkol sa iyong isyu , mangyaring bisitahin ang website sa ibaba. Good luck at magkaroon ng isang magandang araw. Manual Kawasaki Bajaj Wind 125 Documents
Oct 21, 2011 | 2006 Bajaj Wind 125
Is it a lost passport? year 1995 ipinalakad ko sa agency ang pag aayos ng passport ko. pero di ko na nakuha sa agency ang passport ko, pero ready for pick up na raw sya..
Hi there.
Kung 1995 mo pa pinalakad ang passport mo at hanggang ngayon ay hindi mo pa rin nakukuha, sigurado akong expired ang passport mo. Kung balak mo mag renew, ideclare mo na lang sia na lost passport. Kelangan mo magsubmit ng affidavit of loss upang makakuha ka ng panibagong passport.
Aug 04, 2011 | Computers & Internet
Walang minor wind ko then ung a?f mixture nya asa 3 ikot na then sa maga palyado pero pag uminit na makena mejo ok na help naman po
    Hi, Naiads_25 maaaring mayroon kang squeaked iyong top end na ito ay karaniwang kilala bilang "INIT Mang-agaw" ang piston heats up nagpapalawak at nagiging sobrang masikip sa silindro magbutas at karaniwang nangyayari higit sa lahat sa 2 cycle engine matapos ang isang sariwang top end gawing muli, ngunit ito ay maaari ding mangyari sa bagong-bagong mga motorsiklo, ang mga ito ay bihirang mga pagkakataon dahil sa mas mahusay na kalidad ng control at edukasyon. Overheating pagkabigo na sanhi ng pistons upang sakupin maraming at ang bawat isa ay dapat na maingat na-diagnosed na upang maiwasan ang mga hinaharap na umuulit na nagkasala at ang karaniwang suspek ay ang mga: 1. Maluwag Fastener nagiging sanhi ng paggamit o base gaskets upang mabunyag o pagkabigo crankshaft seal dulot ng edad, overheating, o paglalakad. 2. Hindi tamang kapulungan ng tambo balbula gaskets. 3. Hindi tama ang oil / fuel premix ratio. 4. Broken, masyadong, o basag fuel line. 5. Karbyurator fuel sipi barado o pinaghigpitan mula sa lipas na fuel barnisan, ethanol putik, dumi, kalawang, o antas ng gasolina sa masyadong mababa float mangkok. 6. Main size jet masyadong maliit. 7. Air filter sa mga hindi wasto, nawawala o hindi tinatakan. 8. May mga mali o hindi wasto nababagay pump at o cable langis. 9. Ang hindi bleed oil pump matapos ang pagpapatakbo ng langis tangke tuyo, gawing muli ng bomba o kapalit 10. Kabilang sa mga dahilan ng kakulangan ng silindro, pagpapadulas clogging ng pampadulas sa pamamagitan ng dumi o basura, bara sa tubo ng langis / linya, tumutulo check valve, tumutulo pump packing, sirang oil pipe / line, langis masyadong malamig sa feed. 11. Maling uri ng langis na ginagamit sa premix o langis tangke 12. Hindi tamang spark plug hanay init (masyadong mainit) at o puwang. 13. Ignition timing retarded, may sira CDI. 14. Sobrang load engine, preno ng pag-drag, nasa kamay pagdulas, transmission level pampadulas masyadong mababa o lagkit sa mataas. 15. Engine coolant level masyadong mababa, masyadong luma, o hindi wastong timpla ratio. Failure 16. Engine coolant pump, pinsala, o mga talata pinaghihigpitan. 17. Radiator barado, palikpik nasira, o may sira cap. 18. Ang hindi sundin ang tamang break sa mga pamamaraan. Para sa karagdagang impormasyon tungkol sa iyong isyu, mangyaring bisitahin ang website sa ibaba. Good luck at magkaroon ng isang magandang araw.
    English Spanish Serbian --------------- Afrikaans Albanian Arabic Armenian Azerbaijani Basque Belarusian Bengali Bosnian Bulgarian Burmese Catalan Cebuano Chinese (Simplified) Chinese (Traditional) Croatian Czech Danish Dutch English Esperanto Estonian Filipino Finnish French Galician Georgian German Greek Gujarati Haitian Hausa Hebrew Hindi Hmong Hungarian Icelandic Igbo Indonesian Irish Italian Japanese Javanese Kannada Kazakh Khmer Korean Lao Latin Latvian Lithuanian Macedonian Malagasy Malay Malayalam Maltese Maori Marathi Mongolian Nepali Norwegian Nyanja Persian Polish Portuguese Punjabi Romanian Russian Serbian Sinhala Slovak Slovenian Somali Spanish Sundanese Swahili Swedish Tajik Tamil Telugu Thai Turkish Ukrainian Urdu Uzbek Vietnamese Welsh Yiddish Yoruba Zulu Filipino Open in Google Translate
    Google Translate
    translate.google.com/
    Google Translate
Free Bajaj Motorcycle Service Manuals for download
Mar 27, 2011 | 2006 Bajaj Wind 125
Maayos po ba e2ng camera ko....... kinakabahan po kc ako ..............baka masira canon po ang tatak ng camera ko powershotA480 PA2LONG NAMAN PO
Hi!
Tutulungan ka namin maayos ang sira ng phone mo.
Paki explain kung anung klase ng sira, pyesa ba o merong error code na lumalabas sa display.
Para mabilis ka namin matulungan
Add ka lang ng comment dito.
Salamat.
Jan 15, 2011 | Canon PowerShot A480 Digital Camera
Nagpapatay patay ang fone ko hndi ko alam kong ano ang sira
Hi Ruby kadalasan maengkwentro ko pag patay-patay yong celphone baterya ay sira na,kung sakali bago ang baterya at segurado ka kung hindi ka segurado palitan muna ng bago.Minsan kasi bago mong bili sira pala factory defect ba kailangan original ang bilhin mo or branded ba.Bago na ang baterya ganon parin pa patay-patay parin ,kailangan munang e reset ang setting para babalik sa dati, gawin mo to GO TO> MENU> DEFAULT FACTORY SETTING.Kapangitan lang dito mabubura yong mga save file messages mo kailangan ilipat mo .If hindi mo to magawa dahil patay-patay hindi makaperform ang celpon mo.Kailangan munang pupunta ng cellshop para e flash ang software ng phone mo yan ang nalang option dahil kompleto sila sa gamit mga kable gagamitin pag flash.Meron kung alam saan magdownload ng software para flashing ,kailangan munang kable para makonek sa celpon mo ang data.Just click this site; http://monk3ybidzness.blogspot.com/2009/01/unlock-your-nokia-mobile-phone-with.html
Ibang patungkol celpon problem;
http://www.askstudent.com/hacking/how-to-unlock-any-nokia-based-cell-phone-and-get-its-unlock-codes-absolutely-free/
Feel free to ask whatever the result.
Hope it may help you;
Regards:
VOTIT
taga saan ka ruby?
Jan 28, 2009 | Nokia 3650
Ask
Pare wala wala akong alam sa games, Pero siguro , kailangan lahat na pc ay nandoon ang games files , siguro kung sino yong mauuna ang ang siyang maging server, at ang lahat ay magkonect doon. Eto pare pag network games na, at pag di mag connect siguro kailangan static Ip address. sorry pare ha hindi pa ako nag explore ng games.
Feb 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
