SOURCE: Kenwood car CD player not working
This means that some one has entered the wrong security code more than 3 times. time to take it to a dealer
SOURCE: Kenwood car radio/cd player Model No KDC-3027
Do you like need the colors codes for the harness like speakers and and all?
SOURCE: kenwood car stereo radio works
tengo un carro con un stereo kenwood kdc -mpv7019 como lo puedo desbloquear
SOURCE: kenwood DPX 9000 MJ CDplayer
Start type the code on the face preset button only 1 to 4 to let it appear this number start from 3110 and press Play/Pause button. do itz until it's get to 3119.... the code is 3112 but it'z quite hard....
maybe ur rite!! solution num 2, put it in the trash!!!!
SOURCE: MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
