Question about Life Fitness Exercise & Fitness
I have an older model Life Fitness X3 Eliptical that wont turn on. Checked power supply, etc. Still nothing, just moved so I am wondering if a plug got unhooked in the console?
Posted by Rick Olsen on
wadingriver
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,223 Answers
Very possible. after i moved many miles away i had to disconnect and reconnect theconnectors on my Lifestepper
Posted on Mar 05, 2019
5 Related Answers
Anonymous
  • 124 Answers
SOURCE: xbox 360 won't stay on
I found this article on Microsoft's website that describes your problem:
http://support.microsoft.com/kb/906101
Posted on Dec 30, 2008
vpaaf
Howard
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Posted on May 01, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Posted on Sep 04, 2009
Anonymous
SOURCE: DOA Life Fitness 9500rhr exercise cycle
You should check your battery-it must be putting out at least 6 volts to get the computer started up-depending on the era there will be a battery near the bottom frame-you will need to remove on of the side covers to reach it-
Posted on Dec 30, 2009
Anonymous
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
Eliptical 9500 HR lifefitness lights then stos
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Start by checking your battery for the proper voltage output. The following are some helpful videos.
Nov 10, 2013 | Life Fitness Remanufactured 95Xi...
Life fitness elliptical X3
The following link will take you to the information we have for the X3 by LifeFitness. Please have your serial number available.
Repair Parts for X3 Crosstrainer by LifeFitness SPORTSMITH net
Oct 23, 2013 | Exercise & Fitness
Life Fitness X3 does not turn on. So I can't set resistance nor intervals with console. Plug was checked and is fine.
follow this steps and fix it.
God bless you
  • Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
    Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
  • 2
    Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
Sep 30, 2013 | Life Fitness X3 Elliptical Cross-Trainer...
We unplugged our Fitline e100 eliptical and moved it and now it will not turn on when plugged in.
Plug a known good appliance into the new outlet and verify power. Then verify all connections to eliptical.
Sep 12, 2013 | Audio Players & Recorders
My Life Fitness Display is completely dead, worked fine the last time it was used 2 weeks ago
11_22_2011_12_21_49_am.gifAdjust for 1/8" and clean the sensor switch. Remember the main boar controller motor control the function for the display board(by power supply, electronic signals like the sensor reed, etc) Tight the flexible cable or ribbon cable and plug with carefully and paciencie, Disconnect the power cord
Oct 22, 2011 | Life Fitness 9100 Next Generation...
Life fitness 95ti belt moving to one side any way of correcting
If the walking belt has shifted to the left, use the Allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left rear roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centred.
Jun 09, 2010 | Life Fitness 95Ti Treadmill 95 Ti
My Life Fitness 5500R (like 9500R ) Recumbent's display works but when I press the program button it doesn't cycle through to Hills, etc.! Suggestions?
sounds like the keypad is not functioning since this is one of their older model I recommend call Life fitness and see if parts are available their # is 1-800-351-3737 they will probably will ask for a s#
Feb 28, 2010 | Life Fitness 9500RHRT Recumbent Bike
Error 1 message on older life fitness t3 treadmill
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
Exercise & Fitness Logo
252 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
gbob59
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
