Question about Laser Office Equipment & Supplies
Where is Laser shutter in JP laserjet p3005 and where is DC controller
Anonymous
SOURCE:
Anonymous
  • 81 Answers
SOURCE: close top cover error on laserjet p3005
http://www.feedroller.com/Store/Service%20Manual/HP%20LaserJet%20P3005%20Parts,%20Service%20Manual.pdf
Hi, this is a link to the service manual for this printer
Posted on Jan 01, 2010
Anonymous
  • 10 Answers
SOURCE: HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Posted on Jan 29, 2010
Anonymous
SOURCE: HP laserjet 5550 not printing cycan. Replaced
You will not find the answer to this problem on any forum as I have searched each one! However I have had the same problem and found out that if you have reseantly replaced or reseated the Paper Pic-up assy you may have not pushed down the plastic top cover which sits directly underneath the Cyan Cartridge, this will cause your 5550/5500 to think there is no problem and carry on printing without any error messages.
I'm just a man doing a boys job, lol
Posted on Feb 23, 2010
Testimonial: "Wow! Thank you sir. That was the problem. I had not touched the paper input assembly. So obviously, a user did this. Thanks again!"
Prefab
Stuart Smith
  • 152 Answers
SOURCE: problema con impresor hp laserjet
Hello, this error related to the additional memory installed into the printer. It could be just the memory or the Formatter board itself. The memory can can be removed quite simply.
1) Turn the power off to the printer.
2) Slide the right side cover off, moving it towards the back.
3) Remove the memory DIMM from the formatter board.
4) Turn the power to the printer back on.
Does the printer come "READY"? If yes, then the memory is bad, If NO then the formatter is bad and will need to be replaced.
A good source for part www.partsnow.com
Posted on Jan 15, 2011
BaronVonNuke
Mark Schmit
  • 1915 Answers
SOURCE: 57.0 error on Hp LaserJet P3005
According to the service manual this is a sub cooling fan error. This fan is on the left side of the printer. 25365811-vovdf0wduqj1a05k1fbz2dih-2-1.jpg
Posted on Jan 14, 2015
When I initiate a print job on my HP P3005 laser printer it makes a roaring sound and then I get a error 52. I have read its the fuser and then I read its the laser scanner. Which one is it? Tom
Error 50.x related to fuser &52 for laser scanner assm.
For tec guys only: Open laser scanner assembly, remove laser scanner motor rotor, lubricate the shaft fix it back. (dont do this job with bare hands) check best of luck
Sep 21, 2011 | HP LaserJet P3005 Printer
When i on the printer then "standard top bin full pls remove paper" shows massage. I have HP laserjet printer 3005 dn . so how can i solve this problem.
You have a broken sensor flag most likely or a defective sensor. Sensor and flag located under the top cover in the top right hand back corner. Also check to see if the cable is connected on the sensor and DC controller. If everything is ok, mostly likely defective DC controller.
Often I do repairs on printers because the customer does not use it properly or just plain abuses it. Just read the manual before using.
Aug 25, 2011 | HP LaserJet P3005 Printer
Error 52.0
Hewlett Packard P3005 52.00 Error - Indicates a critical Laser Scanner error has occurred.
Loose cable connections or faulty laser scanner.
*** The Laser Scanner should only be accessed by qualified individuals. ***
Resolution - Power cycle the printer - if the error persists, change the scanner.
Part Number Laser/scanner assembly RM1-1521-030
www.partsnow.com
Dec 28, 2010 | HP LaserJet P3005 Printer
Does not print in magenta
1Check the problem color laser shutter. Clean the shutter as
necessary. Replace the shutter if it is deformed or
damaged
For the cartridge with the problem (color missing), check
the developing-bias contacts to the high-voltage PCB.
Clean contacts, if dirty. Replace defective parts if the
contacts are deformed or damaged
Replace the laser/scanner for any missing color. Calibrate
the printer after replacing the laser/scanner.
4if problem persists then change the hvps & dc controller then calibrate the printer fully five times ur problem will be resolved.....
Jul 02, 2010 | HP LaserJet 2700n Printer
Hp laser jet p3005 printer when switched on it shows no display and it doesnt print also
check ypur power cable or you may have a problem in your formatter board,
Apr 08, 2010 | HP LaserJet P3005 Printer
Hp 3005dn prints blank pages, even the configuration pages requested from the machine itself
if you haven't any error message then you may have a problem in laser shutter, check and reseat your catrtidge, or you have a problem in your DC Controller
Apr 01, 2010 | HP LaserJet P3005 Printer
Hp4345 51.10 error i have replaced the laser unit, dc controler board, engin power supply and the pfc power supply, the 2 cables from the llaser to the dc controler
It's still a laser beam detect error, you need to make sure the safety shutter is opening when the door is closed. It blocks the beam from your eyes and also the beam detect sensor. If all is good, you could have gotten a defective laser.
Nov 09, 2009 | HP LaserJet 4350 Printer
In HP LJ p3005 DN Printer when i given to selftest continious blank page comes i have checked using change scanner assemblay and formetter but problem not solved pls suggest what to do
try removing the cartridge shutter, maybe is not opening. if after that you continue with the same issue without any errors there's a chance it would be the power supply
Aug 18, 2009 | HP LaserJet P3005 Printer
51.20 error message on HP laserjet 4250n printer
It is an error with the laser scanner unit
1 Press ( SELECT button) to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and dc controller
PCA (J83 and J84).
4 Replace the laser/scanner assembly.
See Laser/scanner assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
If nothing from above works and the printer is no longer in warranty, it is possible if the printer is being used in a very dirty or dusty enviornment that the lens and optics of the laser/scanner are so full of debris that the beam detect error occurs. You can remove the top cover and the big black box in the center is the laser scanner assembly. Remove the screws securing the top cover of the laser scanner and remove and clean up all the optics to include the main mirror in the front. I usually use a damp q tip and for the mirror I slide up from toner cartrdige shutter area and observe from the top as it cleans the mirror. Removing the complete assembly on this model is not easy since there are a couple of cables going to the dc controller which are difficult to remove so removing the top of the assembly is easier.
Here is the service manual:
http://www.feedroller.com/Store/Service%20Manual/LaserJet%204250-4350%20(%204200-4300)%20sm.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 26, 2009 | HP LaserJet 4250n Printer
HP LaserJet 5200tn printer that doesn't print dark enough.
If that's okay, then these are the other possible causes:
Transfer roller is defective or incorrectly installed. If the
transfer roller loses conductivity, it cannot effectively pull toner from
the drum to the paper.Transfer roller is defective or incorrectly installed. If the transfer roller loses conductivity, it cannot
effectively pull toner from the drum to the paper.
Action 5
Inspect the transfer roller for correct installation and contact. If the transfer roller is damaged, replace it.
High-voltage connector springs are dirty or defective.
Action 6
The high-voltage connectors are mounted on and above the dc controller and protrude into the toner cartridge cavity. Check the springs for functionality. Clean if dirty, replace if defective or missing.
Laser/scanner door is not opening correctly.
Action 7
1. Remove and reseat the toner cartridge.
2. Check the laser/scanner shutter door for proper operation. If it is defective, replace the laser/scanner assembly.
The dc controller is defective. The dc controller contains the high-voltage circuitry.
Action 8
Replace the dc controller.
Mar 05, 2009 | HP LaserJet 5200tn Printer
55 people viewed this question
Top Laser Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Barbat Nae
Barbat Nae
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
