Question about Vision Televison & Video
On bunker hill security camera 63129 in the menu under system what does s-roloc mean and what does the options for it mean also (SECAM,PAL,NTSC,AUTO)?
Im trying to get my night vision to work better and can't figure out what those mean. And I have no idea what to set the color contrast and bright levels at. I've played around with it all but nothing is helping so far
5 Related Answers
Anonymous
  • 168 Answers
SOURCE: Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Posted on Jan 16, 2007
Anonymous
  • 3 Answers
SOURCE: DVDs Play in Black and White
is it a uk dvd in a uk dvd player and not a copy? if so is your tv and dvd both set to PAL or PALi mode? check both one of the two may be in NTSE mode this would cause it to be Black and White OR it could be your scart cable (it wil be a pal/ntse problem) (
Posted on Feb 14, 2007
Anonymous
  • 13 Answers
SOURCE: Avermedia A301 minicard NTSC/PAL/SECAM/DVB-T/FM
Here (Direct Link From Asus -- Dont let Vista throw you off this driver should work in XP also)
http://dlsvr03.asus.com/pub/ASUS/nb/Drivers/TV_Tuner_AverMedia/VT/V1.6.0.82_V1.1.0.26/TV_Tuner_AverMedia_A301_vista.zip
Posted on Apr 04, 2008
Anonymous
SOURCE: Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Posted on May 14, 2008
Anonymous
SOURCE: Sony HandyCam SR10(NTSC) working with my Philips 21PT2443 model
Hi Pawan, Now I am in the same situation as you were. I am planning to buy one sony camcorder from US. But it supports only NTSC. But My TV is philips 29PT7322, User Manual says it supports, NTSC and PAL colour systems. But I am not sure it works or not. Can you please help me with your experience. Thanks in advance, Kinod
Posted on Jan 30, 2011
Bush TV set up colours look like looking through night vision lenses.
Try to reset the unit to factory default settings.
If the TV is under any kind of warranty, return it while you can.
Also, without knowing what kind of TV, Plasma, ect. it is had to pin point your problems.
Hope this helps
Mar 22, 2014 | Televison & Video
What does it mean when I have double vision on all channels and dvd on my pioneer sd-533 hd5 big screen floor model?
follow this steps and fix it. God bless you
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Nov 04, 2013 | Pioneer SD-533HD5 53" Rear Projection HDTV
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Ican't qdjust the color on my Samsung LED screen
Follow the below mentioned steps :
1.Turn on the LED TV and let it warm up for 30 to 40 minutes before making any changes or adjustments.
2. Put on the lights that you would normally use when watching the TV. You want to create the same ambiance that would constitute normal watching conditions for you. Make sure there is no glare or reflection from other items in the room such as a mirror.
3.Open the menu on the screen of the LED TV with your remote control and find the options for adjusting the color, contrast and brightness. Menu options will vary by TV, but look for options that will say "Contrast," "Color" and "Brightness."
4.Start with the "Brightness" control. It would be best to have a DVD playing so that you can get a better idea of the control settings. Pause the picture at a place that you can see a variety of scenery, such as sky, mountains and people in the forefront. Adjust the "Brightness" by pressing the up and down arrows until you are happy with the picture. Press "Save" or "OK" to set the brightness at this level.
5.Repeat this with the "Contrast" and "Color" controls, remembering to save your settings. Look for the "Mode" setting. Press the arrow to get to "Normal" or "Movie/Cinema." Press that setting and save it.6.Turn off any settings that are titled "Flesh Tone Correction" or "Vivid Sports." These will make the colors unnatural, use up energy and damage the TV over time.
Jun 26, 2011 | Computers & Internet
What is the best picture settings ,like color,tent ,contrast,brightness..ect..
Just a suggestion, since you gave no model information, no specific directions can be given. <div><br /></div> <div>If your set, through the main menu, offers the choices of 'Warm' and 'Cool,' try both to see which you like better.</div> <div><br /></div> <div>The first offers more intense colors, the second (which we prefer) is much more natural to our eyes with flesh tones and single colors closer to nature.</div> <div><br /></div> <div>If you don't have those choices, try varying the color intensity first, and tint second since the last one is pretty easy to find one that looks more like life.</div> <div><br /></div> <div>Brightness and contrast are highly dependent on the viewing room so there isn't really a 'right' or 'wrong' setting for this.</div>
Aug 24, 2010 | Televison & Video
Contrast on my acer monitor is bad how do you adjust it
You can use the monitor's own settings, but that doesn't work very well. I just bought an Acer V233H monitor myself, and I am very disappointed about the quality of contrast and color.
However, I have NVIDIA video card, which comes with software that you can use to adjust gamma, colors, contrast etc. That worked better for me. Still not perfect, but better than the monitor's own settings.
Oct 15, 2009 | Acer 19" LCD Monitor
Lines on tv
Try these:
Contrast: 53 Brightness: 56 Color: 44 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Feb 11, 2009 | Philips 42PFL3603D 42 in. LCD TV
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
Fuzzy white lines
YOUR tv DEVELOP a problem in the video ocillator or the tunner section have this set check by a qualified tech.to solve your problem good luck.any more contact [email protected] i hope by now you have gotten your set fixed the repairs will cost you about between $50.00.to $200.00 good luck.
Feb 25, 2007 | Sharp 32U-S60 32" TV
Televison & Video Logo
300 people viewed this question
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
