Washing Machines Logo
b
bimal kumar agarwal Posted on Jan 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What can be the fault in whirlpool washing machine which is causing wide voltage fluctuation whenever plugged to main supply
Voltage of main supply becomes normal and stable as soon as the washing machine plug is removed from the board. The machine is top loading, 8Kg size with heater model whirlpool 800h.
Adam Truesdale
Level 3:
Master:
  • Master 634 Answers
  • Posted on Jan 11, 2019
Adam Truesdale
Master
Level 3:
Master:
Answers
634
Questions
0
Helped
156497
Points
1822
I would have guessed your washer may have alot of dirt and dust inside if its got alot of usage. How old is it. How long has it been happening. If its new you may want to check the amps for the machine and then ask is the outlet rated for that amps. If its 20 amp machine and your outlet is 15 and the breaker is also 15amp its going to need a better wire upgrade.
Lollo Pop
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 134 Answers
Lollo Pop
Expert
Level 2:
Cheetah:
Answers
134
Questions
0
Helped
73774
Points
301
Insufficient power supply.
Cord is too light.
Try another outlet close to the fuse board, if problem persists you have a problem with your supply authority
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Aug 16, 2009
SOURCE: Tascam DM-24 power supply voltage (+5v) too low for stable...
power supply needs to be replaced
Anonymous
  • 174 Answers
  • Posted on Jul 23, 2012
SOURCE: UPS does not supply power under 150~ volts
UPS will provide constant voltage out put.
The average working condition of UPS is 170 to 270 volt.
Below the level may not work.
Brett Cirbo
  • 101 Answers
  • Posted on Oct 29, 2013
SOURCE: this 03 saturn ion interior / heater blower fan
The problem is most likely the heater control head, or the blower motor resistor.
ideaal
Pieter Vleeshouwers
  • 2029 Answers
  • Posted on Jun 19, 2016
SOURCE: I have whirlpool 360 top load washing machine. Voltage fluctuations is happening while on hot water mode and spinning mode. What should i do?
Electric field or an armature problem in the motor maybe here is a manual
Service Manual free download schematics datasheets eeprom bins pcb repair...
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Jan 20, 2017
SOURCE: I have LG 42LN5300 which is reading 230VDC at led + plug and no back lights. All other voltages going to main board are OK, I changed main board because of flickering on and off screen, so is it MB
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Testimonial: "I ordered and replaced inverter board, no change, picture is still dim pulsating while everything else works. Power board is separate on this model, so anyone know why voltage is 230VDC at LED+ point when it says on board it should be 157VDC for 42 inch, could it be the MAP3202 IC which causes higher voltage, or another component?"
2answers
High temp alarm goes off every few hours. Fridge and freezer seem to be cooling maybe not at its best.
Well if the alarm is going off then there is a problem, get it taken car of asap before you ruin a fridge and freezer full of expensive food.
2answers
Hello! I am trying to fix a Vizio LED TV that does not power on at all and has no LED lights lit, and have followed a few YouTube videos. I dont have all of the details of the TV in front of me but the...
unplug the set wait an hour then with a magnfying glass look at all your "can" capacitors on your powerboard if any of them are rounded on top have pinholes on the top they are bad replace them capacitors charge then discharge power if they are only working partly as a group you will have voltage fluxuations and not enough power to turn the set on
Temperature gauge keeps fluctuating whats the cause
Fiats have a reputation for electrical/electronic problems as they age and even when they are not very old they can manage strange things that even sometimes defeat the dealers, though the same can be said of many modern vehicles. I used to look after a Ducato motorhome and fortunately didn't need to get involved with much electrical work - the only faults were caused by the coachbuilders rushing around and being careless and not by Fiat.
I am not sure if the temp gauge is driven by the engine management or is a traditional circuit but either way the temperature gauge is in effect a voltmeter of sorts. Assuming the gauge is ok, the reading will only fluctuate if the voltage in the circuit fluctuates and that could mean the supply voltage is fluctuating or the resistance of the ground path is fluctuating.
With the traditional circuit the gauge is supplied by an electronically stabilised voltage and the ground path resistance is varied by the engine coolant temperature sensor and fluctuations could be anything from a faulty instrument voltage regulator, through faulty wiring or connections to the temperature actually fluctuating.
If the gauge is driven by the engine management the same approximately applies but checking the circuit becomes much more complex due to the need for circuit diagrams and specialised test equipment, though these would not be needed just to check the security of the gauge in the printed circuit of the instrument panel.
What does F11 error message stand for on my Whirlpool awo 9565 washing machine?
The F11 fault code indicates a serial communication error between the Machine Control board and the Motor Control board. This can be caused by several different problems.
A failed Machine Control board could be failing to provide the Motor Control board with proper voltage. If this is causing the F11 code, then the Machine Control board would need to be replaced.
The Machine Control board could also be failing to supply proper voltage to the door lock assembly. The Machine Control board would need to be replaced for this failure as well.
Voltage flows from the Machine Control board to the Door Lock Assembly. The Door Lock then energizes and closes the Door Lock MAIN Switch. Voltage flows out of the Door Lock Main Switch to the Motor Control board. So if you have power into the Door Lock Assembly but not out of the Main Door Lock Switch, it will give you an F11. If so, you will need to replace the Door Lock Assembly.
You could have a bad Motor Control board that is causing this failure. A bad wiring connection between the Motor Control board and the Machine Control board could also cause this fault code. A bad wiring connection between the Motor Control board and the drive motor is also a possible failure. A failed drive motor could also cause the F11.
With so many possible causes for this failure, I recommend calling a service technician to diagnose and repair the problem in your washer. If you are able to unplug the washer and check the wiring connections, you may be able to find a loose wire harness connection that is causing the problem. Much of the diagnosis for the potential problems noted above requires live voltage checks. I do not recommend conducting these types of checks yourself. Unless you want to take a chance and replace the Machine Control board and the Door Lock Assembly,
1helpful
Washing machine plugged in but no lights on the front when I select the programme.
If there is no power at all to the panel or board then it is possible that there is some damage to the main controller board and circuit. it can be fault within the board, could be the power supply section -DC side - or there is fault in the processor or memory.
In both cases you need to remove the front panel to confirm by measuring the voltage present.
2helpful
2answers
Fault code EF electrolux EWT806 what is the problem
So we just fixed our EWT806 after it suffering the dreaded EF fault... The problem... Too higher mains voltage coming into the house! Albiet within specification from the supplier, the Electrolux EWT806 doesn't like anything around 250 volts! Obviously a poor design on the control board which is unable to accept a wide supply voltage!
Solution, isolation transformer inline with the machine. Now it runs like a dream!
2helpful
Whirlpool duet washer not draining or spinning
sounds like the drain is blocked. remove the lower front panel from the machine and there you will see next to the pump a drain plug,, unscrew the drain plug counter-clockwise and drain and remove the plug and screen. clean out any socks or whatever else found its way down there. put plug back in and start wash cycle,, all should be good.
if it is still not draining then you could have a bad pump ,, use a volt meter to test for voltage at the pump when it is in drain cycle,, if there is voltage then the pump is bad,, but if there is no voltage then the problem could be at the main control board.
c...
I have whirlpool 650d, Its a new one. I am seeing PE error in the display, quite often. Due to this one hour washing takes, 2 hours, 3hours. How do we get over this error. Voltage in my area usually...
Phase error does mean low current only a current rectifirer will solve this will keep voltage regulated dipending on the load of machine it could be expensive to buy a proper voltage regulator for it
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
